Water Pooling - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-07-2011, 12:40 PM   #1
Water Pooling
Hello,
I just wanted to know if anyone had any ideas on how to get rid of pooling water. I just bought a new house and it has a back yard that is mostly a hill, when we get hard rains I get a big puddle right behind the house and it ends 5 to 10 inchs right before my slab. I want to get this issue fixed before it comes a BIG problem. I was thinking of backfilling filling it with dirt or do you think it would be best to put a drain in. Please let me know what you think..
Matthew
MatthewTL is offline   Reply With Quote
Old 03-07-2011, 01:51 PM   #2
Rewards Points: 1,418
It would be a good idea to regrade the land so there is more slope down away rom the house.
The water has to flow or be pumped somewhere else if it is not to pool up in the back yard.
If you put in a drain, that has to go somewhere, not into a septic system or a city sanitary sewer.
Old 03-07-2011, 05:18 PM   #3
I have a large lot and I am THE bottom corner of a good size hill. I am going to dig a trench and fill it with stone/riprap to prevent all of my neighbors' run-off from entering my property. I am also installing two retaining walls with french drains directly behind the house to redirect the rest of the water around my house. My only visible water issues is my garage because it is low compared to soil against outside and severe errosion in places (exposed roots, no grass).
Grading the lot away from the house is always necessary to prevent water issues. French drains are a good option when grading the lawn is not possible or does not actually send the water anywhere (pooling). Also, a small retaining wall with french drain is great if you don't have enough exposed foundation on the house to enable grading away from the house properly and the hill is too steep for a french drain to impact faster moving surface water.
sippinjoes is offline   Reply With Quote
Old 03-07-2011, 07:07 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 338
Ayuh,... It's Always better to drain things,...
Have you got enough grade to do so,..??
A shallow swale is all it takes...
Bondo is online now   Reply With Quote
Old 03-08-2011, 09:59 PM   #5
ur built-in pool
I'd suggest you do some research on whats called a "French Drain" To make the french drain work you need a place to drain the pooled water to. Is there a swail or ditch close to your property line in the backyard? Another option is to dig a shallow trench - like a spades width wide and deep - dig the trench to the drainage swail, lay drainage tile in the trench then cover the low area with topsoil. Then you need to seed the area - Wow, now its getting to be a lot of work. Still, if you can handle a shovel its something you can do yourself
Gerald Allen is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 06:07 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
