Water Loving Exterior Plant Ideas?? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-23-2011, 09:41 AM   #1
Question
water loving exterior plant ideas??
The border of my house in the back yard gets very wet after a rain which causes the basement to get a little damp. It's not too bad, but I think it would be helpful to plant a water & shade loving plant/shrub/bush that can withstand all the water. I'm not looking to get into a big project. I'm just looking for something to put around the house that would help with sucking up all the water when it rains.
If you have any other easy ideas, let me know. Thanks guys
ILOVECAKE is offline   Reply With Quote
Old 09-23-2011, 11:27 AM   #2
Most willows like wet areas. Just don't plant them where the roots can get to your septicsystem. They sense the water and head right for it sometimes plugging it, sometimes crushing it. Japanese iris, iris versicolor, Louisiana Iris all love boggy conditions. Don't confuse them with the bearded iris which like well drained soil on the dry side. Siberian Iris also like moist soil but a little less boggy than the others.
rollinastang is offline   Reply With Quote
The Following User Says Thank You to rollinastang For This Useful Post:
ILOVECAKE (09-23-2011)
Old 09-23-2011, 03:45 PM   #3
Wow, you know a lot. Thanks for all the suggestions. I will look for those
Old 09-25-2011, 10:24 AM   #4
Don't know it all, yet!
rollinastang-
Excellent suggestions!
ILOVECAKE, are you sure you want plants? I would think that a better drainage system would be more appropriate here. I'm a yard nut and have absolutely nothing against plants. R's suggestions would be good for a low site that stays wet but I don't know about depending on plants to take up the water from going into the basement.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 09-25-2011, 10:45 AM   #5
I agree with Downunder. You might want to waterproof the wall to prevent water intrusion and then add plants if you wanted to. Another water loving plant choice is the Papyrus. Tall and wispy. Not sure if they are available in your zone.
Horseygirl is offline   Reply With Quote
No hot water past the valve at top of hot water heater-?- Daulton Plumbing 4 04-03-2011 02:47 PM
Lost Hot water pressure brile Plumbing 11 11-28-2010 02:59 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
