Water Fountain Out Of Landscaping Blocks ?? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
View Poll Results: Is this site part of the DYI Netwaork?
Yes 0 0%
No 0 0%
Maybe 1 100.00%
I dont know either 0 0%
Multiple Choice Poll. Voters: 1. This poll is closed
Old 06-30-2009, 10:02 AM   #1
Lightbulb
Water Fountain out of landscaping blocks ??
I am wanting to build a water fountain using normal landscaping blocks. I am using a pond liner for water retension. The circle will be inside the liner. I was wondering how I would make sure that the wall will not fall forward during the winter fron the ground freezing because the fountain would be empty of water. I was going to glue the blocks together instead of using mortar like a normal brick layer would. Does anyone out there have any ideas or thoughts? Please feel free to give me any advice you have.
Thank You,
Brian
Mono is offline   Reply With Quote
Old 06-30-2009, 10:12 AM   #2
the Musigician
DangerMouse's Avatar
hi and welcome to the forum!
sorry, but i don't seem to follow the concern about falling in the winter.
do you mean building this above ground or using the blocks at ground level? can you draw up a quick sketch and post it?
DM
Old 06-30-2009, 10:16 AM   #3
DM
No I am building this under ground and the top will end up at ground level with a cap around the whole circle. It will be roughly 1ft deep so 3 layers of 4" tall block and then a 2" cap on top of that. Does that help explain?
Thanks,
Brian
Old 06-30-2009, 10:25 AM   #4
the Musigician
yup, now i stand under you... if you use blocks like this, their shape will prevent any falling in, and as long as the liner keeps them dry, they use glue on retaining wall blocks all the time.
DM
Old 06-30-2009, 10:51 AM   #5
The blocks will be in the water with the normal pretty side facing inward towards the center of the fountain. The liner will go under them and behind them so that the liner will be hidden. Does that help???
Old 06-30-2009, 11:07 AM   #6
the Musigician
yup, i'd go ahead and just stack the blocks, no glue. if they shift at all, which i don't think they will, you can just push them back. but i'd make some sort of cover, even just ground contact plywood, for the winter so snow doesn't pool and freeze in it. that could crack your blocks.
so then...you want the blocks to be viewable in the water? any fish planned too?
DM
Old 06-30-2009, 11:24 AM   #7
the Musigician
"Is this site part of the DYI Network?"
no, the _D_o _Y_ourself _I -n network is based at pleasedontpullthetrigger.org
i think here, we're all part of some sort of diy network though.... uhyup
Po)
DM
Old 06-30-2009, 11:25 AM   #8
Thank's for input. No I dont plan on any fish. Way too many stray cats and wildlife that would want to get them for food !!!! LOL Just trying to dress up the yard a little. Mostly flowers and a Sunset colored decorative stone surrounding the water. Maybe some lighting if and when i can get to that part. I am leveling the dirt today. I picked a VERY BAD Spot to dig this fountain by hand. LOTS & LOTS of tree roots and those BIG Greeb shrub roots throught the area. Thank God for hatchet's and tomahawks. LOL
Take Care & Good Luck to you,
Happy 4th of July to you also !!!! **********
Old 06-30-2009, 01:05 PM   #9
I don't get the poll ???
It's a different web-site then DIYnetwork
Tags
fountains , ponds , retaining walls , water
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Why do water heaters have two elements? gp_wa Plumbing 21 02-09-2012 02:56 PM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 04:01 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Underground circuit to water fountain t2000kw Electrical 5 08-19-2008 09:51 AM
