Water In Basement - Landscaping & Lawn Care - Page 3 - DIY Chatroom Home Improvement Forum
Old 04-15-2012, 03:28 PM   #31
Ravenworks's Avatar
See how that works when you start with the basics first.
Glad to hear it!
Ravenworks is offline   Reply With Quote
Old 04-15-2012, 05:46 PM   #32
Rewards Points: 160
Glad to hear it!
thanks, that is what i was hoping for. is there anything i can do about that bottom block holding water?
jhack836 is offline   Reply With Quote
Old 04-15-2012, 07:04 PM   #33
bbo
Non invasive? I'd put a dehumidifier by out for a few weeks and se what happens.maybe out just needs to dry out if you have in fact addressed the issues by grading and getting a better run on the roof water
bbo is offline   Reply With Quote
Old 04-15-2012, 09:18 PM   #34
Rewards Points: 160
i posted a pic of the bottom block. currently it does look like its drying up but you can still see its holding a little water. its been downpouring for the past few hours and no water at all is coming t hrough the wall!! im sooo happy right now
Old 04-16-2012, 06:00 AM   #35
Rewards Points: 1,492
There could be an underground void at that corner that fills with water, and some water percolates into the concrete block before it all percolates into the soil below.
You would need to either use extreme measures to reduce ground water from the surface, or dig up the ground and fill that void and backfill the foundation again.
Old 04-16-2012, 04:20 PM   #36
Rewards Points: 160
i will probably keep working on the grading because with all the rain we got this weekend the block never got any darker so that is a good sign
Old 04-16-2012, 06:11 PM   #37
Ravenworks's Avatar
Old 04-17-2012, 07:31 PM   #38
Rewards Points: 160
i put a huge fan in front of that bottom block today and let it run on high, the block was all dry. i turned it off for the past 2 hours and i can see small dark wet spots, hopefully it just needs to dry out from all that water down there for the passed year. the house was a forclosure that sat from last jan to sept when i bought it with NO downspouts, the elbows ran straight into the ground and flooded the basement! i did alot of work already on teh house. had to put a new furnace in and 6 glass block windows in teh basement, the old ones were rotted out and some had just that black backer board that had holes in it.
Old 04-17-2012, 10:06 PM   #39
Concrete & Masonry
Rewards Points: 548
I could probably write the pre-face to a novel on how water migrates through the interior of a block basement, mortar daming and options to drain the interior cells of block, but it's been a long Spring already. I think you're on the write path with allowing the basement time to dry out & correcting the exterior grade & gutter issues, although I wouldn't be completely surprised if you continue to have issues with that corner in the near future......
jomama45 is offline   Reply With Quote
Old 04-17-2012, 10:24 PM   #40
Rewards Points: 160
yea i wouldnt be surprised either but it is a good start, the real tests will be when it downpours for a week straight this summer
Water leaking in through door on main floor down to basement. DIYinTraining Building & Construction 15 12-14-2011 06:24 PM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 10:08 AM
Need help figuring out walk-out basement water intrusion issue toomanypets General DIY Discussions 18 08-29-2011 08:34 PM
Advice for a novice: Mold and water damage in basement xoxJanette General DIY Discussions 1 12-29-2009 06:54 AM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
