Water In Backyard - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 01-14-2007, 10:10 PM   #1
Water in backyard
The very back of my yard floods every time we get a good rain. Both neighbors yards seem to be much higher than mine, so that is the cause of the flooding. I have a neighbor directly behind me, and it doesn't seem to be a problem for him. Is my only option to have dirt put down and try to raise my yard?
I am a first time homeowner so I apologize if this is a dumb question.
stevenblick is offline   Reply With Quote
Old 01-15-2007, 10:27 AM   #2
it'd be the easist option.............
mdlbldrmatt135 is offline   Reply With Quote
Old 01-15-2007, 04:36 PM   #3
Another vote for raising the yard, your neighbors may very well have done the same to eliminate their water problems inadvertantly giving you a problem. Let the battle of the highest yard begin
Tmb9862 is offline   Reply With Quote
Old 01-15-2007, 07:45 PM   #4
digit
Send a message via Yahoo to esel
Hi stevenblick, Might want to belay raising the yard.Two reasons.
1 - depending on local laws and the natural lay of the land for run-off
it could be illegal for you to crowd water over on your neighbor. There is generally a common run-off area designed into lot layout that typically is defined as being where the property lines meet.
2 - You might consider the cost of buying and trucking in soil as this could get expensive,you didn't say how big an area is in question.
Also consider installing an underdrain to the nearest community drain [ pipe,ditch etc.] Plastic pipe is cheap and generally only has to be buried shallow. I have also had people build up their yards only to find that they have crowded the water back into their foudations,and then they call someone like me to regrade. Be aware and lots of luck
esel is offline   Reply With Quote
Old 04-24-2007, 03:43 PM   #5
regrade
regrade the yard for a pitch of 1/4 inch to 1/2 inch per foot away from foundation. if you choose to add soil to your yard, not to add so much as to cover your foundation. about 4 - 6 inches of foundation should still be exposed.
Basic_Homeowner is offline   Reply With Quote
Old 05-01-2007, 08:41 PM   #6
Similar situation here in Missouri. Neighbor's yard thick with grass and weeds not letting water flow away quickly. We now have a pool in back corner. We're putting the house on the market, and our city home inspector said we needed to install a catch basin to dissipate the standing water. I'm trying to get some info on where to find 'geofabric'. Is that similar to weed barrier? Any ifo appreciated.
stavros516 is offline   Reply With Quote
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 04:28 PM
Water level in boiler system Barefoot Brian HVAC 3 10-19-2006 02:11 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
