Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 06-15-2011, 10:30 AM   #1
Walkway over French Drain
I installed a French Drain along my entire back of the house (no drain tile below retaining wall). I wanted to put the flagstone pavers back where they came from, but since I can't put crushed gravel over the french drain, I am not sure how to make them level and solid. I have other places i can use the pavers, so I am not too concerned about keeping them there. In fact, I don't have enough large pavers and have to space them a lot to make it work. I don't want to use pea gravel, but I want it to drain well and still feel solid under foot. Any recommendations?
sippinjoes is offline   Reply With Quote
Old 06-15-2011, 11:28 AM   #2
Civil Engineer
I do not understand why you feel you cannot put crushed stone above your French drain. Perhaps you can describe exactly how you built the French drain. On this forum, and elsewhere, people use the term French drain to mean a lot of different things, if it is not described, it is impossible to understand exactly what was built.
Old 06-15-2011, 11:33 AM   #3
If the French drain is of solid material (such as bricks) and on the surface then you would not be able to put gravel on it and you may not put a walkway over it except as a bridge. Water has to flow on the level along the French drain (a subtle ditch).
You may put gravel or flagstones etc. over an underground French drain, even one less than 12 inches below the surface.
A French drain (named after the country) is on the surface.
A French drain (named after a person) is underground.
Both are commonly found running along the perimeter of a building foundation.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 06-15-2011, 12:26 PM   #4
My french drain is a perforated corrugated 4" pipe laying in a bed and covered with #57 gravel. I dug a trench about 1.5' to 2' deep, laid down landscape fabric, laid in the pipe, and then covered with #57. I have the same basic setup behind the retaining wall. Both exit in the same area and is a dry creek bed under construction. If I put down anything finer than #57 (sand or 3/4 minus) it will eventually just wash into the gravel and potentially mess up flow of water. I have only used a hand tamp on the gravel and that hasn't produced a very solid walkway.
Tags
french drain, gravel, pavers, walkway
help, brick walkway to traverse french drain D270 Landscaping & Lawn Care 4 04-15-2011 11:47 AM
French Drain to Drain Roof DIYTKINNEY Landscaping & Lawn Care 2 11-08-2010 05:53 PM
Existing French Drain Question chrisswany Landscaping & Lawn Care 4 08-17-2010 11:55 AM
Berm and/or French Drain Solution?? (Pictures Included) appleman01 Landscaping & Lawn Care 9 03-20-2010 10:37 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
