Everyone uses the side gate to enter our yard because there is parking on that side. There is approx. 12-14' to our porch which is a couple feet off the ground with three concrete steps to walk up to get on the porch. There are wooden handrails on either side of the steps and a large 10' deep porch and side door that everyone comes in to enter. The problem is the walkway from the gate to the concrete steps. This area is shaded on the left by a very old Magnolia tree with large roots, many that have risen above ground. On the right is a large old Pecan tree that has roots above ground but not as many. There are old square concrete stepping stones with pebbles embedded as a walkway. These stepping stones are too far apart and far from level. One has pushed up at one corner and is especially troublesome. My elderly parents with canes have great difficulty maneuvering this walkway to come up on the porch--even with our help! I want to put in a walkway that will be smoother and more level but I don't know what to do about the tree roots and also the bottom step (or base) of the concrete steps seems to have sunken in a bit so that it is lower than the ground around it. Water doesn't really collect and stand there when it rains, but it seems like the walkway would have to first be dug out to be slightly below that first step or base so rainwater would drain away from the house. If the roots are cut, will the trees die? This Magnolia tree is HUGE and this portion of the roots is a very, very small percentage of the total root system. The walkway is about 5-6' from the actual trunk of this bigger Magnolia tree. The pecan tree roots are minimal and would be easier to eliminate but it is a smaller tree and I am afraid cutting roots on it would create a bigger problem because they are a larger % of the total tree. Does all this make sense?
I just measured and the big Magnolia tree is actually about 10-1/2 feet from the walkway. The smaller pecan tree is about 3-1/2 foot from the walkway on the other side. The base of the concrete steps is actually three square concrete stepping stones placed next to each other and the last concrete step is only 4 inches above those. When you stand on the bottom step it looks like the ground slopes up slightly toward the gate. If it is not good to cut the roots would it be better to build up the path, filling in with dirt or gravel or rock dust? Would that mean I would need to cover up the base of the concrete steps, even perhaps raising that part of the walkway 4 inches to the bottom step? I want to make sure the drainage is good. My house is pier and beam and there is about 18-24 inches between the ground and the bottom of the floor joists.
If you want to keep your trees,I would think anything would be better than cutting the roots,remember the feeder roots extend to the drip line of the tree.
Thanks for your response. Some of the larger Magnolia roots stick up really high. Would it damage the roots to shave them down--or slice off the top of the rounded top part of the old, gnarly roots?
It's too shady for grass to grow--the Magnolia tree is huge and the pecan tree also has large limbs and leaves and provides lots of shade. The Magnolia tree keeps leaves all year. I need something smooth to walk on, especially for my elderly parents who use canes, and my dad sometimes has to use a walker.
How about using smaller flagstone pieces? I have them around a large Linden tree and because they are smaller you can meld them into the ground as you go. It makes the path look well traveled and lived in.
You'd have to pay someone to do it, but pervious concrete is great for installing walkways and patios under the dripline of large trees. It would have to be set on a gravel base, but would yeild a nice path in your situation. You might need to bring in some topsoil to cover the roots on either side of the path, since the path would likely be built above grade a little but.
Pervious concrete is not a DIY project, and most batch plants won't sell it to you unless you're specially certified to install it. That's the case around here at least. So you'd have to involve a certified contractor.
Pervious concrete is basically the consistency of a concrete rice krispy treat. It lets water and air infiltrate the earth below.
I don't think I have ever seen pervious concrete before. I did go out to a stone and marble place that sells the chips and stone dust. A couple of nurseries around here use it for walkway material and it packs down hard and looks good. I don't know if that would work with roots or not but it could be fit around roots.
How do I go about finding out if anyone in my area works with or installs pervious concrete?
Thanks so much for your suggestions. I appreciate everyone who has posted.
I would suggest contacting concrete batch plants in your area directly. Determine if they sell it, and they will recommend installers to you. The Concrete Promotion Group (a general concrete industry rep) normally has a representative (and website) in major metro areas, and they have links to pervious installers on their website.
Ill see what I can find out about the concrete. I live in a small town--a hundred miles east of Houston.
Regarding the small flagstone pieces. Is it possible to get scrap pieces of flagstone on the cheap?
google: covering tree roots with dirt
and read the various responses. Seems that in general, you shouldn't cover tree roots as they somehow suffocate (don't ask me how). How pervious concrete would prevent this I don't know either but it might; I'd like to see results of some long-term use before I'd put it under a specimen tree. Why not check with local arborist or agriculture extension office for additional advice? One site suggested bark mulch but that wouldn't work too well for someone with a walker.
Good luck.
Never build up soil around a tree or woody shrub. This will slowly kill them! Never shave roots! its like skinning them alive. The vascular system is just under the bark
I know it's been a while since anyone has posted about this but I'm hitting the same problem. While this isn't a solution for me, it may be for you. Are you able to build a wood deck walkway to the steps? This way, it's raised a bit and the roots can do whatever they want below the deck.
I've been cringing at the suggestions of cutting, shaving or even covering over roots. Barring mechanical intervention or unintended erosion, tree roots appear where the tree wants and needs them to be. Removing them, altering them or covering them risks damage or even death to the tree. The consequences may not appear immediately but show up over years until its too late. Damage to a tree's root system can put the tree into stress thus making it an easier target for disease or pests.
IMHO The best suggestion I can see is the raised walkway built in the fashion of a deck.
Not sure if anyone is still reading this or still looking for advice. We have an oak tree that is about 100' tall and the center of the trunk is about 5' from our sidewalk, and 10' from our front porch. The area between the sidewalk and porch is a flower bed.
The tree roots have pushed parts of the sidewalk up and over, so it's a tripping hazard. After having a certified harborist come out (with a PhD no less), we were told that we could shave down the surface roots - no more than 6" down - without harming our tree. It's just going to be one major root that is approximately 1' thick, if not more. We are going to jack up the concrete sidewalk, get them to come out and shave that root down, then rebuild the sidewalk further from the tree and closer to the porch. They've already come out and shaved down roots from our side yard (next to the driveway) but that area was well outside of the drip line. With our tree, it's so old, mature, and stable, that grinding down a few roots 6" wasn't going to do any harm to the tree.
Our fix won't solve the problem of roots growing under the concrete sidewalk, but it did save the tree. The other options were to cut the tree down, trench 24" down around the front porch (which would have created structural problems and with high winds that we get from hurricanes and storms, the tree could possibly topple onto our house), or build a deck over our existing porch and sidewalk that would allow the roots to grow under.
So basically I'd call in a local certified arborist and discuss your situation with them. Having roots cause problems with walkways is nothing new, and they'll be able to give you sound advice on what actions you can or shouldn't take.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
