Walkway Near Big Trees - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 02-07-2012, 06:30 PM   #1
Walkway near big trees
the tree roots has caused a corner of my concrete walkway block to raise 1.75 inces high. A condition that can cause someone to tip and fall. Should I have a mason person lift the block first and then have a tree person to cut the roots enough to level the concrete block? Have the mason person come back to return the concrete block?
gee1222 is offline   Reply With Quote
Old 02-07-2012, 06:34 PM   #2
Rewards Points: 14,014
Cut the tree down and have the stump ground, move the walkway away from the tree. Just cutting the roots back is only a temp. fix. They will just grow back.
Old 02-07-2012, 07:36 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Cutting the roots could kill part or all of the tree.
titanoman is offline   Reply With Quote
Old 02-07-2012, 10:01 PM   #4
A Little Of Everything
Rewards Points: 1,364
Is this a joke?
DrHicks is offline   Reply With Quote
Old 02-08-2012, 03:52 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 498
Originally Posted by DrHicks View Post
Is this a joke?
I wondered the same thing. Cutting down the tree would be the absolute last thing to do.
Old 02-08-2012, 12:29 PM   #6
Rewards Points: 790
How far are the roots away. A good rule of thumb is that if the root is underneath the canopy of the tree (where the branches extend) and it larger than an inch in diameter, it could be damaging to the health or structure of the tree. It if is right next to the tree and a large root, cutting it would NOT be a good idea. Google images of trees blowing over in storms because roots were ripped up.
Then again, if you're talking about a small root that is not close to the tree, you could be okay cutting it. Knowing the distance would be easier to help you.
cibula11 is offline   Reply With Quote
Old 02-10-2012, 03:09 PM   #7
Is this a joke?
My brief experience in this forum is to take joecaption with a bit of salt. Seems his first responce is to destroy things, and start the project over. Must be a demolition guy...
BobGerard is offline   Reply With Quote
Old 02-14-2012, 09:12 AM   #8
Rewards Points: 27
You can pour 10 yards of walkway concrete in a day. If you screw up or don't like the results, you can break the concrete back out in a day, and then pour again on the third day.
Try growing a tree to maturity in a day.
Wrooster
wrooster is offline   Reply With Quote
Old 02-14-2012, 09:35 AM   #9
Nope not a demo guy. Just have worked on many larger propertys with super long tree lined driveways and walkways around the house and have seen the owners year after year trying to control all the lifted areas using differant methods.
One cut the roots back on a 100 plus year old Pin Oak tree 4' back from the walkway. The tree died.
He cut the roots back along a 1/4 mile long driveway, now all the trees are leaning, the drive is still lifting in some spots and dropping in others from rotting roots. He gave up and had gravel laid down the whole length of the drive and a couple times a year grades it out. Looks and rides much better now.
Natural mulch for Privacy Trees and Fruit trees cprao Landscaping & Lawn Care 0 07-30-2011 02:59 AM
Walkway near big trees--how to deal with roots! jetstover Landscaping & Lawn Care 16 07-26-2011 06:21 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 11:12 AM
Tips for landscaping trees on solid rock!!! Cindyhello03 Landscaping & Lawn Care 4 06-15-2010 07:01 PM
Paint the brick or not? Walkway? Advice NEEDED! Carssson General DIY Discussions 24 09-08-2009 05:52 PM
