Vinyl Siding On A Wood Fence - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-02-2012, 10:24 PM   #16
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
The last two posters are right on.
(boards on the other side, creating a true privacy fence).
titanoman is offline   Reply With Quote
Old 03-11-2012, 12:48 PM   #17
The Fence Guy
TheFenceGuy's Avatar
Either that, or replace the fence entirely if you want vinyl. Vinyl and wood are going to react differently to temperature and humidity changes, so you could end up with a lot of problems with the two parts separating if you try just putting vinyl siding on top of wood. If you want the low maintenance and clean look of vinyl, you're better off starting out from scratch.
TheFenceGuy is offline   Reply With Quote
Old 03-11-2012, 04:57 PM   #18
Happy to help
Lighting Retro's Avatar
Originally Posted by kwikfishron View Post
Run fence boards on the other side, offset from the gaps of the original fencing.
It’s called a “privacy fence”.
Vinyl Siding is a poor choice for many reasons imo.
Agreed. I almost think you will qualify for "you might be a redneck" type of jokes if you install siding on your fence.
Lighting Retro is offline   Reply With Quote
Stone veneer over wood siding ukrishnan87 Building & Construction 6 07-31-2011 12:34 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
