Vinyl Siding On A Wood Fence - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-02-2012, 05:21 PM   #1
vinyl siding on a wood fence
The wood in my backyard fence has been shrinking to where I want to improve the privacy (it backs onto a street) - can vinyl siding be installed on the fence ?
Lincolng is offline   Reply With Quote
Old 03-02-2012, 05:30 PM   #2
Rewards Points: 13,450
It can if your willing to spend almost $100.00 a square (10 X 10') including trim and nails for it, what type fence do you have now. A picture would be nice.
Old 03-02-2012, 05:38 PM   #3
A standard pressure treated wooden fence with boards installed upright. Posts are about eight feet apart and fence is about six foot high. I am wondering if the weight of vinyl siding will be a concern. ( too dark for a picture now but can try tomorrow)
Old 03-02-2012, 05:48 PM   #4
What weight? I can pick up a 2, square box by myself. Not a factor.
Old 03-02-2012, 05:50 PM   #5
Excellent. Thanks. Looks like I have a project to work on as our temperature improves...
Old 03-02-2012, 05:51 PM   #6
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I think the looks would be a concern.
Sounds like something we would do here in Missouri.
titanoman is offline   Reply With Quote
Old 03-02-2012, 05:57 PM   #7
What fasteners to use would be my main concern. Reguler roofing nails will rust off within a few year with pressure treated wood. I'd use stainless steel roofing nails. And there not a stock item most places and not cheap.
Old 03-02-2012, 05:57 PM   #8
The way I am thinking is that the vinyl would be on the "inside" portion of the fence ( side facing the house) and built onto the panel (between the posts and cross beams) ... hmmm... will have to pass idea by her majesty for aesthetics approval now...
Old 03-02-2012, 06:00 PM   #9
On the fastening hardware I was thinking outdoors fence screws - weather proof. Same as we use on decking but shorter no doubt.
Old 03-02-2012, 06:11 PM   #10
Tom Struble's Avatar
Rewards Points: 2,002
fences i would wager move around alot more than the side of a house
Tom Struble is offline   Reply With Quote
Old 03-02-2012, 07:48 PM   #11
Drywall contractor
Rewards Points: 1,070
Agree with Tom. Sounds like a bad idea. Once the siding is on there and the fence starts moving/shifting, for whatever reason, the nails will likely tear out and your siding will look worse than the existing fence....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-02-2012, 08:02 PM   #12
Thanks for the input and insight from your experience all. Will have to definitely rethink this one or even search for examples of this being done. Essentially looking to block off the view cause by shrinking fence boards. Any replacement ideas most welcome.
Cheers
Old 03-02-2012, 08:18 PM   #13
kwikfishron's Avatar
Rewards Points: 378
Run fence boards on the other side, offset from the gaps of the original fencing.
It’s called a “privacy fence”.
Vinyl Siding is a poor choice for many reasons imo.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
woodworkbykirk (03-02-2012)
Old 03-02-2012, 08:51 PM   #14
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,114
installing boards on the back of the fence is the only logical solution as kwik has mentioned
vinyl is notorious for coming off houses in heavy winds. now add having it on a fence where wind should be able to pass through it and your gonna have vinyl all over the yard after a major blow
woodworkbykirk is offline   Reply With Quote
Old 03-02-2012, 09:12 PM   #15
Many thanks all. Appreciate it.
Cbeers
Stone veneer over wood siding ukrishnan87 Building & Construction 6 07-31-2011 11:34 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
