Vinyl Fence Post Cap - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 12-12-2011, 07:33 PM   #1
Does anyone know where I can buy 2 4.75-in x 4.75-in white vinyl pyramid fence post caps in the style of those illustrated in this link: http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
(The link shows 5-in x 5-in, and I want 4.75-in x 4.75-in.)
I purchased 2 5-in x 5-in fence posts, cut them in half and installed them(filled with cement) as posts on which to mount some water and electrical components.
Everything went well until I tried to put caps on them. Apparently, one of the posts was from old stock and was 4.75-in x 4.75-in. I did not notice this when I made the purchase. The 5x5 post caps are too large. The only 4.75-in x 4.75-in caps HD is able to special order are of a different style. I will use them if I have to but prefer to use the same style as all the other ones I have installed.
It is too late to replace the mis-sized posts with true 5x5s.
Silkcityflorida is offline   Reply With Quote
Old 03-11-2012, 12:54 PM   #2
The Fence Guy
TheFenceGuy's Avatar
4.75 x 4.75 caps solution
You're going to have a real hard time finding that size, standard caps are 5x5 or 4x4. Since there is only .25" difference, you might try using vinyl putty to fill in the extra space.
TheFenceGuy is offline   Reply With Quote
Old 03-11-2012, 01:25 PM   #3
Rewards Points: 12,882
Shim it out with vinyl lattis. Lowes sells it.
Tags
cap , fence , post
Broken Fence Post in patio! Tomperro Building & Construction 11 04-21-2011 03:27 PM
Fence post heaving Canadianboy Landscaping & Lawn Care 9 02-04-2011 01:45 PM
concrete anchor for cedar fence post matt76 Landscaping & Lawn Care 0 06-25-2010 09:04 AM
Porch Enclosure Vinyl post stillworking Carpentry 1 03-18-2008 06:07 PM
