Vinyl Fence Post On Bedrock - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-03-2011, 12:01 PM   #1
Rewards Points: 508
Vinyl fence post on bedrock
How would you install a vinyl post over bedrock? I was thinking I could epoxy a piece of rebar in the bedrock, then fill the post with concrete. What do you think?
benjamincall is offline   Reply With Quote
Old 07-20-2011, 09:46 AM   #2
The Fence Guy
TheFenceGuy's Avatar
How to install vinyl fence on bedrock
We would recommend core drilling into the bedrock, then putting a plated post in the hole and pouring hydraulic cement around the post. Then use a 4" or 5" EZ-SET (depending on the size if the posts), and slide your vinyl post over the plated post and EZ-SET.
We don't sell EZ-SET online (yet) but if you call we can help.
TheFenceGuy is offline   Reply With Quote
Old 07-20-2011, 10:12 AM   #3
Rewards Points: 508
Unfortunately, I'm using 4-3/4" actual OD fence posts. I like the look of the EZ-SET, though.
Broken Fence Post in patio! Tomperro Building & Construction 11 04-21-2011 02:27 PM
Fence post heaving Canadianboy Landscaping & Lawn Care 9 02-04-2011 12:45 PM
concrete anchor for cedar fence post matt76 Landscaping & Lawn Care 0 06-25-2010 08:04 AM
Replacing an older fence - should I use same post holes? isiginamo Building & Construction 5 03-31-2009 06:35 PM
Porch Enclosure Vinyl post stillworking Carpentry 1 03-18-2008 05:07 PM
