Vines....HELP - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 11-04-2013, 02:31 PM   #1
Rewards Points: 172
Vines....HELP
So we bought this house with vines completely covering the entire fence around the pool. Both sides (if that wasn't obvious already). I just spent most of the weekend yanking it all down. I'd like to let it dry out and just burn it. How long will this take to dry enough to burn? or is there any better ideas? I don't want to have to take it anywhere because there's a ton of it. I thought of renting a chipper, but that seems expensive (over $100), and I'd have to find a tow vehicle for it. And what could I use to kill the roots and keep it away? The pic only shows a small portion of what I have to get rid of.
nateshirk is offline   Reply With Quote
Old 11-04-2013, 02:33 PM   #2
Rewards Points: 172
That's actually not the pic I was trying to post. But it does the trick.
Old 11-04-2013, 02:55 PM   #3
Rewards Points: 12,868
Loose the vines and you loose all the privacy.
Vines in a chipper will just wrap around blades.
Unless you pull out the roots there going to grow back.
A total vegetation may kill them but also nothing else will grow there for about a year.
Old 11-04-2013, 04:03 PM   #4
K&B Designer
Live_Oak's Avatar
I like the living privacy fence. Much better looking than a classic chain link, that's for sure!
As far as burning the stuff, you'd need to wait a month or two for it to dry out enough, and then get a permit from your municipality. Or check with your local fire department first. It's been awful dry to even think about setting anything on fire. Frankly, burning it as a method of disposal isn't a great idea and is prohibited in many locations.
Bagging it and treating it like the yard waste that it is is the best idea. Call your local trash pickup and find out when they do yard waste pickup.
Or, if you have enough space, you can always compost it. There should be enough stems in that along with the green leaves that it should compost rather well without having to add anything else to it but some moisture and the occasional turn with a fork.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
Old 11-04-2013, 11:30 PM   #5
Rewards Points: 172
There is actually a wooden fence under it, so I'll still have the privacy. I'll look into composting. I've never done that before.
Old 11-05-2013, 06:02 AM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 136
not true at all
Kill Ivy shumakerscott Landscaping & Lawn Care 32 07-21-2011 11:06 PM
install low deck 12" away from house to allow climbing vines? (PICS) AKelly Landscaping & Lawn Care 2 05-24-2011 10:18 PM
Round Up Or Bleach rjordan393 Landscaping & Lawn Care 10 03-11-2011 09:26 PM
Fall care for Clematis vines gma2rjc Landscaping & Lawn Care 9 11-24-2009 08:41 PM
basic questions about growing vines joeyboy Landscaping & Lawn Care 11 08-26-2007 02:15 PM
