Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 11-15-2007, 10:20 PM   #1
weekend warrior
vibratory plate for asphalt grindings?
I just had a truckload of asphalt grindings put down on my drive.
It's a little loose and I wanted to know what is the best way to pack it down a bit to make for better driveway conditioins?
What about a vibratory plate? Roller? Or just good 'ol time and rain?
johnny331 is offline   Reply With Quote
Old 11-24-2007, 12:08 PM   #2
'scaper
I have had blacktop millings dumped on a driveway before and found that a plate compactor tightened things up nicely. Just don't expect it to re-harden like brand new asphalt or anything, but it will pack really tight. It'll just re-loosen somewhat over time, especially when people driving/parking on top of it go and make sharp turns. So, yeah. Tamp it.
Stone Guy is offline   Reply With Quote
Old 11-25-2007, 08:19 PM   #3
If you are going to compact it with a plate tamp be sure you add lots of water first... 15% to 20% moisture content will let you pack it quite tightly I would spread it and turn a lawn sprinkler on it for a few hours (even while I was tamping it if it isnt too cold there)... the surface may loosen up but eventually the whole thing will settle in nicely for you... a heavy coat of emulsified asphalt could stop the loosening of the surface but you probably have to hire a parking lot sealing contractor to do it for you... there is no practical way for a homeowner to spray it on thick enough
panhandlion is offline   Reply With Quote
Old 11-28-2007, 06:53 PM   #4
so-elitecrete
compacted, there was heat & liquid asphalt to bind the mix together,,, now you've just got a bunch of crumbles,,, millings're fine in the right spot but you'll need, as suggested, to spread an asphalt emulsion over the mat & have it compacted,,, otherwise, the tires'll just push crumbles everywhere.
so-elitecrete is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Replacing Rotten Sill Plate Material Tester Carpentry 6 03-28-2011 09:08 PM
Keyed locks for windows, no sill plate, help! steveefer Carpentry 1 10-09-2007 11:13 AM
Hollow wood door with hole where the hing plate goes earlc General Discussion 4 07-08-2007 02:21 PM
Adding closet to carpetted room. Sole plate on top of carpet? roysoto Building & Construction 2 09-23-2006 12:01 AM
