Using WalkMaker To Build Patio - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-05-2011, 11:45 AM   #1
Using WalkMaker to build patio
Hi All,
I am planning to make a patio using walkmaker (belgium block).
The patio will be divided into 2 section.
1st section will be 6' X 10' sqft and on the level of ground.
2nd section will be 19' X 10' sqft and it will be around 6'' to 8'' above the ground.
Basically it will be a step up patio.
I am planning to dig the ground about 6'' and fill in 4'' of gravel for 1st section.
For the 2nd section i am planning to just wipe the grass off and then place the retaining wall around the border.
then fill in the gravel for the retaining wall.
Once this is done, I am planning to use the walkmaker and create the necessary concrete pavers.
Please let me know if i am thinking correctly.
Is there a faul in my design.
Am i missing some thing here.
saithani
saithani is offline   Reply With Quote
Tags
walkmaker
concrete overlay or build deck on cracked patio Larkymills Building & Construction 2 06-23-2011 05:50 AM
Patio Cracked & Sinking silvabul Building & Construction 3 05-04-2011 09:53 AM
Build a covered patio on existing slab Dornier Building & Construction 12 03-21-2011 06:55 PM
How do I Build Brick planters around patio itaska71 Building & Construction 3 03-31-2010 04:24 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 08:11 AM
