Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 05-04-2009, 11:25 AM   #1
Question
Using sawdust for landscaping
I recently had a stump (hardwood-oak) ground out this past weekend and was wondering if I can used the sawdust that was bored out for anything usefull outside or if I should just take it to the dump?
tripower is offline   Reply With Quote
Old 05-04-2009, 11:27 AM   #2
Xtreme DIY'r
Mix it with grass clippings/leaves & put it somewhere to compost
Old 05-04-2009, 04:29 PM   #3
Don't know it all, yet!
Or use it as a light mulch. It is not very attractive in most uses. You could mix it in some soil and leave it to break down- but do not use it fresh in the soil where you are planting. It needs to break down first.
Or do as SD suggested. Just depends on which is more convenient in your particular situation.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 05-04-2009, 09:07 PM   #4
What about around trees or azaleas (existing)?
Old 05-04-2009, 09:11 PM   #5
Xtreme DIY'r
I've used sawdust around different areas before
So long as it isn't too thick - or if you can mix it in with what's there
Most of my sawdust goes out around my son's play area
Old 05-04-2009, 09:12 PM   #6
Learning by Doing
Leah Frances's Avatar
Sawdust and wood chips do not compost well. Do not mix them with compost, unless you like sawdust and wood chips in your compost.
I just spread a cubic yard of recently chipped spruce stump (RIP) around my azaleas. It's not the worlds most attractive mulch, but it will help to keep the weeds down and protect them.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-04-2009, 09:20 PM   #7
It was a dark and stormy
Yoyizit's Avatar
It may attract termites.
Leftover sawdust from stump removal proofer Landscaping & Lawn Care 18 05-07-2009 12:38 PM
