Using RR Ties On A Slope - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-01-2012, 02:34 PM   #1
Using RR ties on a Slope
I have a project that requires using RR ties on a sloped grade which may be 15-16 linear feet of slope. Any suggestions on the best way to accomplish that?
Randy822 is offline   Reply With Quote
Old 03-01-2012, 02:42 PM   #2
Ironlight's Avatar
Can you give us some details on what "requires using RR ties on a slope" means? Are you building steps? Are you building a retaining wall? If a wall, how high? Stepped? Curved? What will it be filled with? What is the purpose? What's the drainage like in that area? Does the ground freeze where this will be built? You gave us the run, what is the drop over that distance?
Ironlight is offline   Reply With Quote
The Following User Says Thank You to Ironlight For This Useful Post:
concretemasonry (03-01-2012)
Old 03-01-2012, 04:37 PM   #3
MarginallyQualified
Rewards Points: 2,464
Try to avoid a RR tie (or PT 8x8) wall more than 5 or 6 courses high; less is better.
Try to terrace the hill from the bottom to top in 2 or 3 (or more) portions.
Learn what a "dead man" is.
Old 03-01-2012, 04:40 PM   #4
Rewards Points: 13,450
I just hate seeing anyone use rail road ties for anything.
Reason being there were removed for a reason.
When they reach a certin age there replaced. The reason there replaced is there starting to rot out.
Old 03-01-2012, 07:54 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,014
Ayuh,..... 'round here,... it's good ties that outlived their Railroad.....
Bondo is online now   Reply With Quote
Pavers over railroad ties ejdonnelly21 Landscaping & Lawn Care 3 01-29-2012 07:50 PM
removing rafter ties: garage conversion neil_9 Introductions 0 09-29-2010 07:55 PM
Adding Collar Ties to make a ceiling Joe1. Building & Construction 18 09-11-2010 09:56 PM
Cutting rafter ties ?? scatkins Building & Construction 23 04-13-2010 03:20 PM
Closet Light issue, Need Help mount on slope bfan781 Electrical 13 04-12-2010 08:31 PM
