Using Hedge Trimmer On A Hot Day - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-07-2011, 06:23 PM   #1
using hedge trimmer on a hot day
Is it a good idea to use a hedge trimmer to trim bushes, etc....on a hot day or is it safer to do it when the sun goes down?
dinosaur1 is offline   Reply With Quote
Old 06-07-2011, 09:07 PM   #2
Rewards Points: 150
Put on the sun screen and have at it.
josall is offline   Reply With Quote
The Following User Says Thank You to josall For This Useful Post:
drtbk4ever (06-09-2011)
Old 06-07-2011, 09:08 PM   #3
Doesn't hurt if I hedge on a hot day vs a cool day?
Old 06-08-2011, 08:18 AM   #4
Rewards Points: 106
Not an expert, but based on my experience, the only things that you need to be concerned with are sunburn, heat stroke, or dehydration. I trim basically year 'round, with discretion, and have never encountered any problems. With bushes and hedges, we generally try to remove any dead sections during the winter, just because it's easier to see what you are doing with less foliage, then shape them as much as possible in late winter/early spring, so that the new growth fills in evenly. The only thing that you will find in trimming this time of year, depending on the type of bushes and how aggressive you are, is that they may not fill back in until next spring. Otherwise, put on your sun screen, wear a hat with a brim, keep the mosquito spray and water handy, and have fun.
Old 06-08-2011, 07:24 PM   #5
Rewards Points: 1,088
Yes, cutting a hedge could stress out the plant.
handy man88 is offline   Reply With Quote
Old 06-09-2011, 06:20 PM   #6
Howdy Dinosaur 1,
I'm "Coach Dave", Garden Expert for The Home Depot and I have plenty of experience with trimming. The answer is "It is better to do lawn work such as trimming in the daylight". The reasons are: when you finish:mowing,trimming,fertilizing, and planting you should always water. You should never water at night because this will cause fungus and create a problem. The other reason for early morning yard work is visibility, it's safer when you can see.
Coach Dave
CoachDave is offline   Reply With Quote
wiring diagram for hedge trimmer batteries mturner25 Tools 1 07-15-2015 07:21 PM
Electric Hedge Trimmer? jage Tools 1 11-09-2009 07:53 PM
Hedge trimmer, cut through the wire (how can I fix it) BostonsBadBoy Electrical 13 10-16-2009 06:29 AM
Repair help w/ a cordless trimmer kennykenny Tools 6 06-28-2009 08:20 PM
Trimmer joists-expanding a rough opening benjamincall Carpentry 2 05-16-2009 05:40 PM
