Using Grass Killer Around Landscaping Rocks - Landscaping & Lawn Care - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-04-2011, 07:05 PM   #31
Originally Posted by concretemasonry View Post
even "weed be gone", if used to excess, can kill or permanently disfigure other vegitation. It is just a broadleaf weed killer, but dosage is important and it can be distruptive to grass if applied in excess. Wbg usually takes 2 or 3 days to should the initial effects of the application.
Dick
dinosaur1 is offline   Reply With Quote
Old 06-04-2011, 09:08 PM   #32
Don't know it all, yet!
Go and ask for "granulated Round-Up".
This is Quick-Pro. It is formulated with a small percentage of diquat for quicker visible results. In my area, it is more expensive than regular glyphosate formulas due to the millions spent on research to come up with just the right blend. At least according to the Monsanto company rep I talked with.
The dawn method is an excellent idea for products such as 2,4-D etc but all glyphosate products I am aware of already have a surfactant added in. If you want to use it fine, it won't hurt. FWIW- the surfactant helps break through the outer leaf surface, especially on plants such as cat-briars, but does nothing to help it stay on longer. You need an oil product, such as crop oil to do that.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 06-05-2011, 12:07 AM   #33
Originally Posted by dinosaur1
<img src="http://www.diychatroom.com/attachment.php?attachmentid=33842"/>
Should I leave the dead grass or remove it and put grass seed.
Old 06-05-2011, 07:38 AM   #34
I would follow a good irrigation and feeding regimen for a few weeks. Some herbicides will cause yellowing if applied too strongly as you did, or on certain semi-tolerant material. For example, Image is labeled for nutsedge control in lawns, but it will also cause a temporary yellowing on some grasses. It's possible that the actual grass is still alive but just burned on top a little. Hopefully.
Old 06-05-2011, 09:26 AM   #35
I will just leave it and see what happens after a few weeks.
wire grass a killer? larie Landscaping & Lawn Care 1 04-16-2011 09:47 AM
From rocks to grass -Q- Landscaping & Lawn Care 3 04-04-2010 07:03 PM
Rocks where I want to grow grass dankreboot Landscaping & Lawn Care 1 04-28-2009 06:07 AM
Sand in the rocks of my desert landscaping... Not Sure Landscaping & Lawn Care 3 06-27-2007 11:14 AM
Dog Safe Grass Killer Sammy Landscaping & Lawn Care 2 03-25-2007 08:22 PM
