Using Grass Killer Around Landscaping Rocks - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-27-2011, 12:14 PM   #1
using grass killer around landscaping rocks
We have large limestone rocks all around our home. I wanted to know the most effective way to kill the grass 6-8 inches out from the rocks so I don't have to use my string trimmer there and also so the grass is easier to cut. I tend to get ALOT of crabgrass in between the rocks too.
Here's a pic:
https://picasaweb.google.com/lh/phot...eat=directlink
https://picasaweb.google.com/pewauke...17909102214450
dinosaur1 is offline   Reply With Quote
Old 05-27-2011, 01:07 PM   #2
concretemasonry's Avatar
Rewards Points: 2,570
You have three choices:
1. Use Roundup, which kills all vegitation in the area.
2. Treat the area with a pre-emergent crab grass controller.
3. Since it is such a small area, pull out the unwanted vegetation.
Dick
concretemasonry is offline   Reply With Quote
Old 05-27-2011, 01:19 PM   #3
Dick
When using Roundup grass killer should I do it on a hot day or a colder day? Now were in the 60's, but the next few days we will be in the 80's.
Old 05-29-2011, 02:12 AM   #4
Rewards Points: 410
Temp don't matter , wind might..
I use roundup for the same situation .
High Gear is offline   Reply With Quote
Old 05-29-2011, 08:24 AM   #5
Too Short? Cut it Again!
Roundup. Nice still day. It is a powerful herbicide. Consumers can still buy it which amazes me at times.
Do get a tank sprayer and mark it for use as for herbicides only. Cost you $20? You can then buy and mix Roundup concentrated in gallons, five gallons or 55 gallon drums if you want. Those cute little gallon things with a spray nozzle attached? $30 or whatever walking out the door with happy consumers who shop at box stores? Crack me up.
Roundup, at least for the application you have in mind, is a non-selective and systemic herbicide. It will kill everything you spray it on. It got approved because it breaks down fast and does relatively no harm to the environment. I personally, am concerned about resistance to it being bioengineered into things like food crops. Corn in particular.
Old 05-30-2011, 11:23 AM   #6
Energy Saver
HomeInsulation's Avatar
RoundUp can get expensive
dinosaur1,
After spending $100+ a year on RoundUp and Ground Clear. I found something called Big N' Tuf Weed and Grass killer at Tractor Supply.
I spent $50 on a 2 1/2 gallon jug about 3 years ago and still have plenty for this season. It's concentrated and kills everything. Even small trees.
Here's a link to the web page...
http://www.tractorsupply.com/lawn-ga...2-gal--4201103
HomeInsulation is offline   Reply With Quote
Old 05-31-2011, 08:58 PM   #7
Are you referring to the Roundup Concentrate? I have a little 1 qt jig of that stuff...man that stuff is pricey. Where do you buy it?
Old 05-31-2011, 10:31 PM   #8
A Little Of Everything
Rewards Points: 1,362
Originally Posted by HomeInsulation View Post
dinosaur1,
Yep! The great thing is that RoundUp has been around long enough that there are off-brand herbicides that do the same thing. MUCH cheaper. Just be careful to note what the percentages are.
DrHicks is offline   Reply With Quote
Old 05-31-2011, 10:50 PM   #9
What cheap option is out there?
Old 05-31-2011, 10:55 PM   #10
HomeInsulation had a link to an "off-brand RoundUp" available at TSC. Here it is again...
I believe Ortho also has their own "roundup" available.
Old 05-31-2011, 11:20 PM   #11
I unfortunately don't have a tsc by me.
Old 05-31-2011, 11:24 PM   #12
Crud.
Well... Off-brand RoundUp is available in a lot of names, in a lot of places. This comment thread has some ideas.
http://www.tractorbynet.com/forums/r...c-roundup.html
Old 05-31-2011, 11:32 PM   #13
When using the stuff around vegetation you plan on keeping be extremely careful especially on windy days.Might suggest using thick rubber gloves with a pair of old socks over them.You then soak the sock and saturate the weed from the base up the stalk.
Jasonlongor1 is offline   Reply With Quote
Old 05-31-2011, 11:39 PM   #14
Good point! What you described is pretty much the old "Rope Wick Weed Wipers" we used to use on the farm. It literally rubbed RoundUp on the weeds.
Old 06-04-2011, 12:07 AM   #15
I bought some RoundUp concentrate today to make 5 gallons. What's the most effective way to use this stuff? Use it when its hot and sunny?
The RoundUp spray gun with the 1 gallon jug costs more than this? Why would people buy one over the other?
wire grass a killer? larie Landscaping & Lawn Care 1 04-16-2011 09:47 AM
From rocks to grass -Q- Landscaping & Lawn Care 3 04-04-2010 07:03 PM
Rocks where I want to grow grass dankreboot Landscaping & Lawn Care 1 04-28-2009 06:07 AM
Sand in the rocks of my desert landscaping... Not Sure Landscaping & Lawn Care 3 06-27-2007 11:14 AM
Dog Safe Grass Killer Sammy Landscaping & Lawn Care 2 03-25-2007 08:22 PM
