Using Air To Blow Out A Sprinkler System - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-10-2012, 06:58 PM   #1
deverson's Avatar
Rewards Points: 77
Using air to blow out a sprinkler system
I have Orbit inline sprinkler valves and when I charge the system with air to blow them out I can't operate the valves electrically. Is there something I'm missing? I've been operating each valve manually but some valves are buried pretty well in the ground.
deverson is offline   Reply With Quote
Old 10-11-2012, 12:37 PM   #2
Too Short? Cut it Again!
If you look at top of the valve body, you should notice a fairly obvious screw or hex nut distinct from anything else on it. This is your manual override screw and will allow you to open the valve to whatever extent you have the flow control knob set to let it open. Just open this screw and the valve should open as if you had activated the solenoid. Remember to screw it back in! Beware that if it has never been used there is a tiny washer or o-ring that might fracture so don't be surprised if you have to replace it. In addition for your purpose at hand, this manual screw comes in handy when you are adjusting sprinklers and flow to them and do not want to have to run all the way back to your controller.
Here is an illustration of a valve, with callouts added, that hopefully looks something like yours? Post again if you hit a snag.
Old 10-12-2012, 06:26 PM   #3
deverson's Avatar
Rewards Points: 77
I am able to operate each zone manually in the yard, not a problem. Just trying to figure out why they don't operate with air pressure and electrically from the nice warm basement. Seems as though whenever I open them out in the yard they are pointed directly at me. I may need a shower but I don't want a shower!
Old 10-13-2012, 09:54 AM   #4
Not sure why you are having trouble. Some valves will not open without pressure and flow (air or water) behind them. So if you are trying to open the valve and then flooding with air, you might switch that around and fill with air first and then see if the solenoid opens the valve?
DIY sprinkler system kimbhoot Plumbing 2 06-15-2012 10:01 AM
Need Help wiring 24VAC Sprinkler System fazlis85 Electrical 7 10-26-2009 08:27 PM
Drive Point Well for Sprinkler System? tigerbalm2424 Landscaping & Lawn Care 0 06-03-2009 06:40 AM
Yard Sprinkler System riverdees05 Landscaping & Lawn Care 1 05-09-2007 06:03 PM
