Underground Sprinkler Blow Out - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 11-09-2014, 06:54 PM   #1
Rewards Points: 562
underground sprinkler blow out
I have never been around a backflow device in underground sprinklers before and now its my job to winterize same. Thats the easy part.
The hard part is its down in a terrible crawl space on other end of house from access hole. Question is can you blow air into the supply line AFTER the backflow device? Thinking it should hold the air pressure in just like keeping water from backing up.
I have access to the supply line without crawling. It is after the bf and before the zone valves
The next issue is valve is leaking anyway,,,thinking of adding an electric valve that turns the whole system on and off. And would need another valve on the electric shutoff on drain side so no crawling required fall and spring
How do you put electric solenoids in and control them from other end access,,,how do you control them???
4just1don is offline   Reply With Quote
Old 11-10-2014, 04:12 AM   #2
Rewards Points: 562
thinking more---if I am relying on elec valves to supply and stay closed to keep crawl space dry,,,what happens in a power failure when valves lose juice and city water is still on?? Does the crawl space fill with water?
Old 11-10-2014, 09:46 AM   #3
Rewards Points: 42
You need to blow out the back flow as well. Is there an shutoff or accessible section of pipe before the back flow? You could install a connection point to blow out the system. If the back flow is leaking, it might not protect your internal water supply. Depends upon the leak.
Valves use low voltage power to open them. If you had a power outage, the valves would be closed. Some irrigation controllers have a master pump relay. You could use it to open your main valve.
Some pics might help.
Dan
djlandkpl is offline   Reply With Quote
Locating underground lawn sprinkler pipes Thurman Electrical 8 06-30-2014 07:33 PM
Underground sprinkler system 4just1don Landscaping & Lawn Care 3 05-24-2014 11:49 AM
How to mend underground sprinkler electrical wire diyatx Electrical 1 02-28-2013 01:47 AM
Using air to blow out a sprinkler system deverson Landscaping & Lawn Care 3 10-13-2012 09:54 AM
Blow out a water line that is not used with a sprinkler system njmike2011 Plumbing 1 10-30-2011 06:38 AM
