Underground Downspout Extensions - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-20-2012, 02:33 AM   #1
Hi all. I'm wanting to install quite a bit of underground downspout extensions on one of my properties. It will connect to 3 downspouts on the right side of my house and 2 in the back yard. Then I'll run it out to the back edge of my property. I want to use the 4" corex pipe. I think it will be about 150' in all.
It seems like it is a rather simple project, just a lot of labor, but probably I am overlooking many things. So I'd like to ask you guys if you could provide a few pointers that are commonly overlooked. Should I install cleanouts? If so, where and how many? Should I install some type of strainer or filter? Or perhaps leaf screen would do the trick? What type of drain exit should be considering? Any other advice?
Thanks!
Mr Brandon is offline   Reply With Quote
Old 03-20-2012, 06:27 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 360
Thanks!
Ayuh,.... If it Freezes there, you might have Problems...
Bondo is online now   Reply With Quote
Old 03-20-2012, 08:40 AM   #3
Too Short? Cut it Again!
Not legal to do this where I am or elsewhere where I have lived in the last decades.
Old 03-20-2012, 11:17 AM   #4
Rewards Points: 768
Why? Is it because he wants to extend them all the way to the edge of his property?
Underground/French drain systems are used all the time.
cibula11 is offline   Reply With Quote
underground electical lines BlueBSH Electrical 11 02-10-2012 04:52 AM
Clearing Out Clogged Downspout Extensions sweaty Plumbing 4 08-08-2011 12:01 PM
underground downspout extensions blocked ibgyahoo General DIY Discussions 6 06-08-2009 12:56 PM
Replacing patio - Relocate downspout slvrbullet98 Landscaping & Lawn Care 2 05-08-2009 09:30 AM
underground downspout extensions joshm Roofing/Siding 3 05-20-2008 10:45 PM
