Under Deck Drainage Problem - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-10-2011, 04:05 PM   #1
Rewards Points: 107
under deck drainage problem
Years ago, when we did an addition, the deck installer built the off the back of the house. There was a downspout that he built around, so that the downspout empties underneath the deck. It drains to the back edge where the stairs are, but then the water pools up and it is very soggy. Any suggestions on diverting the water? I hate to have the deck taekn up to redo the draining I have thought of putting in a series of rain barrels on the deck to drain out another edge. Any other ideas?
Ranger1227 is offline   Reply With Quote
Old 04-10-2011, 10:04 PM   #2
Rewards Points: 106
Without seeing exactly what you have, it's hard to say, but three things come to mind. The first is to relocate the existing down spout by installing a new one at the end of the deck, or maybe one at each end, and sealing the old hole. The second thought is to redirect the downspout, installing, as an example, a 45 right off the eases trough, and angle the downspout to the edge of the deck. The thrird thought is to slip a piece of PVC under the deck so that it carries the water from the existing downspout to the edge of the deck, even if it requires removing a deck board or two.
Cedar deck help mickbiv Painting 11 08-08-2013 09:21 PM
Newly stained deck problem astpeter Painting 4 04-04-2009 07:16 PM
Help!!! Drainage problem flooding basement charlton7 Landscaping & Lawn Care 2 04-12-2008 10:13 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
deck drainage problem darsunt Building & Construction 4 12-30-2006 12:45 PM
