Unbelieveable - HUGE Hole Appears In Back Yard! - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-02-2012, 06:50 PM   #16
Rewards Points: 528
Looks like an abandoned metal septic tank to me.
Fill it in with sand and forget about it.
framer52 is offline   Reply With Quote
Old 02-02-2012, 10:29 PM   #17
Rewards Points: 276
But first, post some pictures if possible. I'd like to see this hole.
Jim F is offline   Reply With Quote
Old 02-03-2012, 10:03 AM   #18
If you check out reply #9 of this thread, there's a link to some pics of the hole.
simileigh is offline   Reply With Quote
Old 02-03-2012, 10:18 AM   #19
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
FWIW, the link works for me.
Old 02-03-2012, 10:39 AM   #20
Custom User Title
Rewards Points: 252
Works for me now. Weird.
no1hustler is offline   Reply With Quote
Old 02-03-2012, 02:04 PM   #21
Too Short? Cut it Again!
As posted, it does not really matter what it was anymore. Just make sure anything feeding into it is capped off. Figure out if you need to file for a permit to fill it or if you municipality or State EPA has restrictions on what you can fill it with. Fill it.
Make sure it is not some evil sinkhole situation with something eating away under it. It looks dry?
A friend once put out a call on a neighborhood bulletin board for concrete chunks around which she poured sand in an old cistern. Quite a few people wanting to redo sidewalks but wondering where to dump the chunks helped her out. They took up a fair amount of cubic space in her giant hole for free. Put topsoil over it and replanted lawn. Looks great. Sand will probably be as cheap as anything and easier to handle than other materials?
Old 02-06-2012, 05:59 PM   #22
Squeaky Floors
This cistern showed up recently during a kitchen remodel, guess we know what was causing that squeaky floor. Measured 11' deep and 7' wide, hard to make out in the photo (attached). Had to file permit, fill and cap. Owner wanted to know what I thought about putting a "Safe Room" down there. Heh.
Unbelieveable - HUGE Hole Appears in Back Yard!-cistern-1.jpg   Unbelieveable - HUGE Hole Appears in Back Yard!-cistern-2.jpg
RenoStruct is offline   Reply With Quote
Old 02-06-2012, 06:31 PM   #23
Rewards Points: 348
Originally Posted by simileigh View Post
Sides seem to be made of dirt....
Like Allan, and now with the sides made of dirt, my guess would be that this is an old drywell. I have seen them filled with all sorts of things, one had a huge roll of livestock fencing. Nice, until the fencing rots away, and then you wind up with what you have, nothing to hold the dirt up anymore, and a big hole appears!
You will need to fill it in. I would poke a shovel or something into the bottom a few times to make sure it won't cave in any further.
Pardon any typos, my IPad has a mind of it's own for spelling corrections!
dougp23 is offline   Reply With Quote
Old 02-06-2012, 08:05 PM   #24
Rewards Points: 276
I see that now thanks.
Old 02-10-2012, 11:04 AM   #25
About 7 years ago I bought a 1950's era house that looked to sit on two lots. The house is situated on the very northern border of the property line. This always seemed a bit strange to me because the lot is so big. A few years after I bought the house I built a 30x33 attached garage. As I was digging for the foundation I found out why there was nothing built there. I ran into a huge concrete storage tank of sorts. We ended up having to relocate the garage a bit and never figured out what the use of the tank was. It sure is interesting what you find buried around these old houses.
RockingM82 is offline   Reply With Quote
Old 02-14-2012, 08:07 AM   #26
Rewards Points: 1,512
An old large cistern (nonporous sides) can come in handy to store rainwater for lawn watering. The water would not be potable unless you had some kind of treatment.
Old 02-15-2012, 07:04 AM   #27
Non-Crafty Newbie
Meenie50's Avatar
I'd like to hear if that link doesn't work for others.... it works when I click on it.
The link works fine for me. That's quite a hole! I hope you figure out what it was and how to fix it!
Meenie50 is offline   Reply With Quote
Old 02-20-2012, 04:16 PM   #28
Rewards Points: 77
Any updates on this? I'm interested to know the outcome...
Doing things almost the right way...
Double is offline   Reply With Quote
Old 02-24-2012, 11:01 PM   #29
Why can't these old cisterns still be used? Was the water collected supposed to be used for something? Why not use it for watering the lawn?
MisterSteve is offline   Reply With Quote
Old 02-25-2012, 08:50 AM   #30
As far as I know, they can still be used as cisterns, provided the sides have not cracked which would cause loss of the water to the ground.
The water would not be potable by today's standards unless treated just prior to use.
Does All Solar Lighting in Back yard really work? KUIPORNG Landscaping & Lawn Care 11 05-27-2008 02:36 PM
Filling a huge stump hole moneymgmt Landscaping & Lawn Care 2 11-28-2007 12:34 PM
interlocking at the back yard KUIPORNG Landscaping & Lawn Care 10 09-14-2007 08:24 AM
Back yard now leaking "black water" tripower Plumbing 5 08-06-2007 04:56 PM
Back Yard Surfaces EAMVT94 Landscaping & Lawn Care 7 03-29-2005 10:52 AM
