Ugly Concrete Slab - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-18-2011, 09:32 AM   #1
Ugly concrete slab
I converted my garage into what is now my living room. Unfortunately I have an ugly concrete slab that we used to park on in front of my living room. I can't afford to have it taken out and sod, but is there something else I can do that wouldn't be so cost prohibitive?
caelucky is offline   Reply With Quote
Old 07-18-2011, 10:53 AM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Look into to having it Acid stained.
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
The Following User Says Thank You to Mr Chips For This Useful Post:
caelucky (07-18-2011)
Old 07-22-2011, 05:39 PM   #3
Too Short? Cut it Again!
Or even polish the concrete I guess.
How about rubber pavers? Quite beautiful, durable, super easy to install over concrete and maintenance is what you do now. If you destroy a piece, just pop a new one in place. Rubber will go right over the concrete and make a little private patio off your living or family room in a weekend. Rubber pavers come in a variety of colors and a variety of full proof patterns.
Don't get the thin faux paver brick crap at box stores though!
http://www.paversearch.com/rubber-pa...troduction.htm
Old 07-23-2011, 08:57 AM   #4
A Little Of Everything
Rewards Points: 1,364
That's what I was going to suggest. Not necessarily a perfect solution, but a whole heckuva lot nicer than an ugly slab.
DrHicks is offline   Reply With Quote
Old 07-23-2011, 09:15 AM   #5
NACE Coating Inspector
mustangmike3789's Avatar
http://www.surecretedesign.com/produ..._ecostain.html
i like using eco-stain vs acid staining. acid staining takes a lot of practice and experimental testing and dilution ratios to achieve the color that you want. i feel that the eco-stains are more HO friendly and a lot less hassle to get the colors represented on the color charts. acid staing interior projects can cause corrosion on metals such as door hinges, window frames, and a/c vents if they are not properly covered and with good ventalation to evacuate the fumes given off as it reacts with the concrete.
mustangmike3789 is offline   Reply With Quote
Old 07-23-2011, 09:28 AM   #6
Do they have that stuff at the Home Depot, where you normally shop?
Old 07-23-2011, 09:42 AM   #7
im sure that they do. if not, one of there experts should be able to guide you in the right direction
Old 07-23-2011, 09:58 AM   #8
You can do it. We can help.
Old 07-23-2011, 10:01 AM   #9
the band around this pool and the small tiles were done with eco-stain with a taupe liquid antique agent applied over it. green acid stains will not hold up outside and tend to turn black when exposed to UV rays.
concrete porch slab questions Queso Bandit Building & Construction 2 06-29-2011 10:31 AM
Fix or Replace Porch Concrete Slab Majoram Building & Construction 10 06-25-2011 02:45 PM
Help stone over concrete slab Johnnyquest Flooring 0 05-20-2011 03:36 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 12:23 PM
PVC underneath the floor (concrete slab) massimo Building & Construction 6 11-19-2008 10:37 AM
