Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 08-01-2011, 11:23 AM   #1
Trying to Repair Toro Electric Starter
Hi, I'm working on a Toro Snowblower CCR 2450. Electric starter is not engaging and disengaging from the flywheel. The electric motor seems fine.
I removed the starter from the blower, took the pinion off the shaft, cleaned the shaft and pinion. Reinstalled it in the blower. Pressed the electric start button, the electric motor spins, the pinion dropped spun the flywheel but did not retract back up. I moved it back up manually. Pressed the electric start button but now the pinion will not move down to engage the flywheel. Tried WD40 sparay but did nothing. Wondering if anyone has any suggestions. Thanks
thimsyrag is offline   Reply With Quote
$1440+ labor only repair on 3 yr. old Goodman unit!?! JMK HVAC 23 05-06-2012 11:45 AM
Electric Dryer repair assistance aggreX Appliances 11 05-23-2010 05:22 PM
Need help with Electric Furnace and HP goodeetwoshews HVAC 7 12-17-2009 10:38 PM
What do you guys think of this roof repair job? darsunt Roofing 7 08-21-2009 09:43 PM
Is my panel sufficient to add Electric water heater andy Electrical 16 04-21-2009 09:34 AM
