Trying To Kill A Stump That Is Sending Up Suckers - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-01-2013, 01:18 PM   #1
Rewards Points: 452
trying to kill a stump that is sending up suckers
I'm trying to kill this stubborn tree stump that is sending up suckers near the base above the ground.
Do I cut every sucker and paint Roundup on every single sucker?
or shave a little off the top of the stump and paint that with roundup?
pman6 is offline   Reply With Quote
Old 07-01-2013, 01:23 PM   #2
concretemasonry's Avatar
Rewards Points: 2,594
Do both because it is still alive. Drilling holes in the top of the stump allows more killer to be applied and soak in before running off or evaporating.
Grinding the stump does a great job.
In any event the area will sink as the roots rot and decompose, so some filling will need to be done in the future, but less if it is ground out.
Dick
concretemasonry is offline   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
CENTERLINE MV (07-01-2013)
Old 07-01-2013, 02:43 PM   #3
Rewards Points: 258
i have heard that drilling holes in the stump and filling the holes with episom salt, then watering it will speed up the rotting of the stump.....
or just rent one of these
https://www.google.com/search?q=stum...w=1366&bih=673
redman88 is offline   Reply With Quote
Old 07-01-2013, 04:06 PM   #4
Rewards Points: 970
If you are wanting to kill the stump with glysophate, do neither. As the suckers develop leaves sponge both sides of the leaves with the roundup. It is formulated to act on plants with active growth. Sometimes good things take a little longer. If you are in a hurry rent or hire the stump grinder.
Old 07-01-2013, 04:12 PM   #5
Rewards Points: 472
don't know how big the stump is , but if you can put a bucket over the stump or cover it up so that the stump doesn't get light , it will die, or get a bag of charcole and light it on top of the stump that will burn the stump eather way will work , may take a couple burn's but that will take care of it
del schisler is offline   Reply With Quote
Old 07-01-2013, 04:53 PM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 998
Ayuh,.... Clorox,... It's cheaper, quicker, 'n better,...
it disperses fast too,...
Bondo is online now   Reply With Quote
Old 07-01-2013, 05:01 PM   #7
General Contractor
CENTERLINE MV's Avatar
Out here, pitch pines are incredibly aggressive. I've had log piles of them send out suckers. What's always worked for me (I've cleared hundreds of acres for habitat restoration in a former life) is flush cutting the tree, plunging the saw in the stump forming a giant "X" an inch deep, and spraying with roundup over the whole stump and filling the "X" never had one resprout
CENTERLINE MV is offline   Reply With Quote
Tree Stump joeg679 Landscaping & Lawn Care 20 01-21-2013 08:54 PM
Rent a stump grinder or "hire" a stumpgrinder? CoconutPete Landscaping & Lawn Care 32 04-18-2011 08:20 AM
How to keep a tree stump from rotting. richcharity Landscaping & Lawn Care 2 06-08-2010 05:20 PM
Grubs Too Big To Kill AllanJ Landscaping & Lawn Care 6 05-24-2010 09:06 AM
Tree stump mdlbldrmatt135 Landscaping & Lawn Care 2 06-16-2006 01:31 PM
