Trying To Find A Chipper/mulcher To Shred Grass/weeds/leaves/branches - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-29-2013, 08:02 PM   #1
Rewards Points: 186
Trying to find a chipper/mulcher to shred grass/weeds/leaves/branches
No luck finding something that'll eat small branches, grass, weeds, leaves. I take a scythe to the overgrown yards around here and kill off the tall grass, sometimes 4-6 foot tall weeds come down, bits of woody branch-like material, etc. Trying to shove this through an $80 Toro vac doesn't work--wet grass.
I need something that'll accept both wet grass and dry leaves and is electric. Small branches should be acceptable; larger branches probably need a dedicated chipper. Essentially what you'd expect if you cut down an overgrown, weed-infested lawn and just dumped it into the top, looking for little pieces out the bottom.
A few hundred bucks seems okay, $500 $800 $1000 is overkill for me. I don't mind dealing with a chipper for branches, but I want a leaf-grass-twig machine because pre-sorting lawn refuse is laborious. Obviously if I'm pruning trees I can stick the branches in something else.
Any suggestions?
If you can't explain why, then you don't know what you're talking about. I'll keep asking until I find someone who does.
bluefoxicy is offline   Reply With Quote
Old 08-29-2013, 08:26 PM   #2
Rewards Points: 44
I have one of these. It's $530. It won't so much for grass but it eats everything else. I have an older model that reduces 7 bags of stuff to 1.
It's nice because it chips, shreds, and vacuums. Sears has the same machine rebranded. I got mine in the clearance center and saved some $$.
http://www.lowes.com/pd_409078-270-2...der&facetInfo=
Dan
djlandkpl is offline   Reply With Quote
Old 08-29-2013, 08:42 PM   #3
Rewards Points: 186
That's interesting, but I'm winding up with what's essentially 3-6 foot long single pieces of wet grass, mixed with small branches and twigs. What I end up with is a giant solid mass of organic matter that doesn't break up without applying force to pull pieces apart.
I mean, those grass clippings are 2-3 feet long, and there's 5 foot tall weed stalks in there. It's a pretty cohesive lump. Think like if you didn't mow your lawn until August, and then took a samurai sword 1 inch from the ground and just cut it all down in one sweep.
Old 08-29-2013, 08:49 PM   #4
Rewards Points: 44
It would work if you could let the clippings dry out before shredding. If you put wet grass through anything that shreds it's going to turn to mush and gum up the machine.
Dan
Old 08-29-2013, 08:51 PM   #5
Rewards Points: 186
Interesting. How does that affect composting? Reduces nitrogen a bit?
Should I just be keeping these in the grass bags for a day or so and then running them through? Might actually be a better deal. It's too bad I can't shred the bags too.
Old 08-29-2013, 09:00 PM   #6
Rewards Points: 44
I think it speeds composting as it reduces the size of the material and it mixes it up. When I do my garden and yard weeding/pruning I put it thru the shredder before it goes in the composter.
The vacuum will suck most of the leafy stuff and small branches. Toss it on the ground and push the machine over it.
Dan
Old 08-29-2013, 09:26 PM   #7
Rewards Points: 186
yeah I know that much, but I mean letting the stuff dry out. It's going to lose a bit more than just water.
Old 08-29-2013, 10:37 PM   #8
Rewards Points: 1,016
Craigslist...
____________
Vince
Old 08-30-2013, 07:42 PM   #9
MarginallyQualified
Rewards Points: 2,464
Hire someone to haul off your debris.
The city might even do it for free.
Old 08-30-2013, 07:48 PM   #10
Rewards Points: 186
But then I wouldn't be able to put it to any use.
Where to find a contractor? sgt_utz Building & Construction 2 09-28-2011 06:15 AM
Can't find good laminate comparison anywhere cpsilo1 Flooring 3 03-20-2011 04:49 PM
Where can I find good contractor and building material suppliers? denniis Off Topic 5 03-10-2009 09:27 AM
need to find wall switch remote..does that exist? tarheelblue Electrical 7 09-05-2008 05:51 AM
find switch to control outdoor light fixture CaymanAg Electrical 1 07-10-2005 08:43 PM
