Troy-bilt Weedeater - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-10-2011, 12:32 PM   #1
troy-bilt weedeater
How do I stop the gas from leaking between the gas tank and fuel lines
wallbanger is offline   Reply With Quote
Old 06-10-2011, 01:05 PM   #2
Rewards Points: 24
If it's new in the last year or two, I would remove the fuel lines, reconnect them, and see if it still leaks; could be that you caught one of them on something, and pulled it loose a bit. If that does not fix it, or if it is more than two years old, I would get new fuel line and clamps from the local hardware or lawn care dealer. Clamps, by the way, in this case, are usually a simple wire loop, with a curl on each end, which you can squeeze with your fingers or needle nose pliers to open, and they do weaken over time, so don't overlook those.
Weedeater one we261 Christy45 Landscaping & Lawn Care 0 07-22-2010 05:35 PM
Troy Bilt Gas Cultivator dangier Landscaping & Lawn Care 0 05-02-2010 10:48 AM
Ridgid or troy bilt Pipeline Tools 1 11-23-2008 12:41 PM
Troy Built engine:what mower decks will fit? boone722 Tools 3 09-21-2008 10:23 PM
Troy Bilt chainsaw cramer Tools 1 06-22-2008 09:53 PM
