Troy-Bilt 2-Cycle Gas Trimmer Will Not Start - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-10-2009, 07:52 PM   #1
[IMG]file:///C:/DOCUME%7E1/Johnny/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]I have a Troy-Bilt 2-Cycle Gasoline Trimmer (Model# TB70SS) that I purchased about 1 1/2 to 2-years ago and it will not start. Enclosed are photos of the unit.
I've done the following and it still will not start:
  • Checked the On/Off Switch
  • I've replaced the gas and added a fresh new tank of 40:1 mixture of 2-cycle oil and unleaded gas
  • I've checked the Spark Plug arrestor and cleaned the screen with a wire brush
  • I've replaced the spark plug with a Champion DJ7Y spark plug with a .025 gap
  • I've inspected the air filter and it looks to be in pretty good condition.
  • I've pulled the starter rope numerous times just in case it is flooded
One of the things I've noticed is that the Primer Bulb will not work correctly. When I press it in to start the fuel flow, it will not depress or return to its normal state immediately, it takes several minutes. Therefore, I can't press it 10 times as the manual states to start it. Does this mean I need to replace the primer bulb? What could be the problem HELP!!!
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start-weed-eater_troybilt-001.jpg   Troy-Bilt 2-Cycle Gas Trimmer Will Not Start-weed-eater_troybilt-002.jpg
g8tkeeper is offline   Reply With Quote
Old 08-10-2009, 09:23 PM   #2
Fuel line blockage upstream of the primer bulb.
I guess you could also remove the plug, make a gap between the plug wire and the engine shell of 3/32" or less, yank the pull cord and look for a spark. A gap of >1/4" will probably overstress the ig. coil.
Old 08-11-2009, 04:11 PM   #3
Kap
Mowing my life away.
Definitely sounds like a clogged fuel line. I would replace them all. Should cost less than five bucks to DIY.
Kap is offline   Reply With Quote
Old 08-13-2009, 11:58 AM   #4
Does it have any spark?
I'd try dumping a squirt of gas directly down the carb to see if I could get any sort of spark. If so, you've probably got a fuel supply problem.
mopowers is offline   Reply With Quote
Clothes Washer Will not start cycle allenzachary Appliances 6 01-11-2011 09:57 PM
Heil Furnace will not start up after cycle pcoslow HVAC 6 04-19-2009 11:01 AM
Ridgid or troy bilt Pipeline Tools 1 11-23-2008 12:41 PM
Troy Bilt chainsaw cramer Tools 1 06-22-2008 09:53 PM
