Trimmer Not Working Starter String Wont Pull. - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-09-2012, 09:35 PM   #1
trimmer not working starter string wont pull.
i was trimming my weeds and the trimmer just stopped running and now the starter pull string wont pull. what do i do or whats the problem?
billy O is offline   Reply With Quote
Old 06-10-2012, 06:38 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,648
Ayuh,... With All the information you provided,....
I'd say it's Dead,.... Buy a New 1....
Bondo is online now   Reply With Quote
Old 06-10-2012, 07:19 AM   #3
Of course that would be after he's checked all the obvious things like empty fuel and oil, dirty spark plug, clogged fuel line....just sayin
creeper is offline   Reply With Quote
Old 06-10-2012, 07:22 AM   #4
Rewards Points: 14,026
Pull the spark plug and try to get it to turn over.
If the motors locked the most common reason would be it was run without oil mixed with the fuel. If that's what happened it's trash.
Old 06-10-2012, 07:51 AM   #5
Bondo's Avatar
Ayuh,... I really doubt any of those things cause a seized motor...
Old 06-10-2012, 09:51 AM   #6
Rewards Points: 120
Agreed. There's no need to mess around with maintenance tasks until the engine is free. First thing, think back to make sure that you used the right gas can, i.e. two cylce versus straight gasoline; if you ran a tank of straight fuel through it, yup, it's probably cooked. If you're sure that you had two cycle fuel in it, remove the pull starter, to see if the problem is in the starter or the engine; the odds probably aren't real high, but possible that the engine stall and the starter bound up are simply unrelated coincidences.
Ryobi string trimmer cgoll Landscaping & Lawn Care 0 06-15-2011 03:13 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Pulling in Flex eNt (vacuum string?) jamiedolan Electrical 7 03-05-2009 11:36 AM
No Pull lube jamiedolan Electrical 7 12-16-2008 12:00 PM
any tricks to re-string pull starter on snow blower? whwestman General DIY Discussions 4 01-14-2008 04:29 PM
