Trimmed An Evergreen Wayyy Back - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-14-2011, 07:51 PM   #1
Trimmed an evergreen wayyy back
Along my driveway I cut back into a big square shrub a good 18 inches, so now I can see all the barren branches/limbs. Is there anything I can do to spur lots of new/small growth on these mature limbs? Its actually a few shrubs grown together.
I trimmed some holes into the top canopy so light can now penetrate into the shrub a little. The heavy hacking was only on the one side to make clearance for car doors.
Mrdippy is offline   Reply With Quote
Old 09-14-2011, 08:45 PM   #2
PE Mechanical Engineer
Thunder Chicken's Avatar
Rewards Points: 844
It depends a lot on the type of evergreen shrub you have. If it is a yew and you cut the branches back so there are no green leaves or buds on them at all, you might have scalped it and it will be very difficult to fill in. A juniper won't come back at all after this treatment.
If you are in northern areas with snow and frosts coming soon, your shrub should be trying to go dormant and hardening off for the season. Now is not the time to try to stimulate growth. Trimming it would have been better left for the spring.
If you are more southern with year round growing, you can just make sure it is watered and gets sun, maybe mulch with some compost for a feed. Basically it it can recover it will just be a matter of time and patience.
Thunder Chicken is offline   Reply With Quote
Old 09-14-2011, 11:46 PM   #3
kmc
Way too little info.
kmc is offline   Reply With Quote
Old 09-15-2011, 08:14 AM   #4
Rewards Points: 1,500
Give it a year to see if new growth fills in.
Some species won't regrow. ONce I had a (scotch?) pine shrub that was getting too big and I picked (pinched) off all the new growth each spring and suddenly one spring it shed the remaining needles and died.
Some species (including blue spruces) will grow and grow no matter what you do. Experts recommend pruning just about six inches worth of outer branches but this just slows rather than stops the ever increasing size.
Eventually some evergreens get so large you have no choice but to cut them down and start over (perhaps with new small ones of the same kind).
Built-In (back) Oven Clearance for NM Cable? dcarpen23 Electrical 4 08-29-2011 11:29 PM
Should I paint before I put drywall back up? Dave K Painting 1 05-13-2011 02:25 PM
Re-shaping back yard, tilling and other questions fox_forma Landscaping & Lawn Care 12 03-15-2011 04:51 AM
sagging kitchen off back of house DanBress Building & Construction 12 03-03-2008 09:20 PM
