Trencher Or Excavator For Drainage Pipes - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 01-22-2014, 08:33 PM   #1
Rewards Points: 398
Trencher or excavator for drainage pipes
I need to dig some trenches for drainage pipes. I will be using 4" pvc piping. I am also digging a swell (probably 8 inches wide). I will need to go through some roots in areas. It will probably be 100ft of digging that needs to be done (no deeper than a foot). The mini excavator is around $200 a day. The trencher is $150. The trencher only digs 5" wide, so I will have to make two passes for the swell. It will work well for the drainage pipe, however. The mini excavator has a 10" bucket.
Malcolm is offline   Reply With Quote
Old 01-23-2014, 07:01 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,728
Ayuh,.... Either machine can dig a ditch for the pipin',....
The trencher is less tramatic to the surroundin's,...
For yer Swale, I'd think the track-hoe would be better,...
But,...
A Swale is more of a Wide "V" shape, rather than a 8" or 10" or 20" trench,...
It should be gentle, walkable, mowable, pretty much Unnoticeable after it's reseeded,....
Bondo is online now   Reply With Quote
Old 01-23-2014, 07:04 AM   #3
Rewards Points: 14,310
Make sure and call Miss Utility first.
Old 01-23-2014, 09:51 AM   #4
Rewards Points: 398
Which one will dig the trench more efficiently considering the roots?
Old 01-23-2014, 11:58 AM   #5
Bondo's Avatar
Ayuh,.... Unless they're Massive roots, either oughta chew right through 'em,....
If the roots are Massive, yer gonna be choppin' 'em with an axe anyways,...
Old 01-23-2014, 12:36 PM   #6
Rewards Points: 152
For trenching, I like a trencher, because it deposits the soil in a berm right along the excavation, so minimizes the footprint and is easy to backfill, but it is not a practical tool for widening an existing trench.
Old 01-27-2014, 07:16 PM   #7
Rewards Points: 219
You'll get a more consistently sloped trench (important for your drainage pipes) with the trencher. The excavator will have a steeper learning curve and you'll make a bigger mess. By the time you are getting the hang of the excavator . . .you'd be done with the trencher. 100' and a shallow with something like the little Vermeer tracked trencher that Home Depot rents could be knocked out in an hour.
red92s is offline   Reply With Quote
Insulating attic pipes thew60 Insulation 4 01-10-2014 02:23 PM
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 07:22 AM
Combining vent pipes in the attic. a4aj Plumbing 5 02-04-2010 11:20 AM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK HVAC 5 11-01-2009 08:15 PM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 09:03 PM
