Tree's vertical growth (Coral Bark Japanese Maple)
A tree that small would be easy to shift to straight. If it were mine, I would use a sharp spade and cut around the root ball, about 15" off the trunk, angling the cut to form a 'V'. From there you should be able to straighten the tree without removing it from the hole by using the spade. Additionally, you could use stakes and wire with garden hose to help straighten any wayward branches- just do a little at a time. If you try to bend a branch completely to straight all at once you may break the branch.
Chris
