Trees Killing My Grass - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 02-10-2010, 10:56 AM   #1
trees killing my grass
it seems like the tree roots are coming out of the ground and killing the grass all over my back yard! does anyone know a type of grass or what i can do?
Garret is offline   Reply With Quote
Old 02-10-2010, 01:00 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 628
Ayuh,... Other than cuttin' the trees down,...
I'm guessin' you're SOLuck....
Bondo is online now   Reply With Quote
Old 02-10-2010, 01:30 PM   #3
Too Short? Cut it Again!
Depending on the type of tree, you can probably call a tree service to remove the surfacing roots for you without worrying about hurting the tree overall. Shop around though. I would also call your city, forest department, university, etc. arborist for free advice.
Grass simply will not grow under some trees even if you get the roots out of the way and plant a shade blend. If the concept would work for your landscape, consider taking the lawn out under the trees and planting compatible groundcovers instead.
Old 02-10-2010, 01:53 PM   #4
GardenConcepts's Avatar
Rewards Points: 150
Cutting the roots will not help. You'll either damage the tree and/or the roots will grow back. I've seen many homeowners cover the roots with soil- this is a temporary fix that can also damage the tree- and if it doesn't, the roots will grow back to the surface.
Trees such as Norway and Sugar Maple, Hybrid Poplars, and Sweet Gum are known for their surface roots. Your solution is to either remove the trees or plant drought and shade tolerant ground cover within the root zone.
GardenConcepts is offline   Reply With Quote
Old 02-13-2010, 08:10 PM   #5
Don't know it all, yet!
Mulch or ground cover. Or cut it down.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 02-14-2010, 04:45 AM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 232
Unfortunatly, I would have to agree
chrisn is online now   Reply With Quote
Old 02-14-2010, 09:47 AM   #7
Poster hasn't been back since he made the post
My neighbor dumped a bunch of dirt over the roots of the trees & planted grass
That was a couple years ago & the trees & grass are both doing fine
He has a mix of trees
Mulch wouldn't work since it is a low lying area by a stream that floods
Old 02-14-2010, 11:24 AM   #8
Whatever grass you pick, pick a hearty shade grass that stays dense. I agree that a moss or ground cover may be more helpful up close to hte tree.
TANC is offline   Reply With Quote
Smoke or steam coming from grass Holt Landscaping & Lawn Care 0 11-05-2009 11:53 AM
Grass seed questions..... Mikey Palmice Landscaping & Lawn Care 4 04-22-2009 09:00 PM
Tree Stump Killing Grass? malsup Landscaping & Lawn Care 3 12-14-2007 09:24 AM
pine/spruce trees and your grass sarahbear Landscaping & Lawn Care 4 03-29-2007 12:42 PM
killing grass around trees THEBIGPUNN Landscaping & Lawn Care 2 06-20-2006 06:31 AM
