Tree Saw Advice & Opinions? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-30-2013, 01:24 PM   #1
Is this wire Hot?
Oh-Fudge's Avatar
Rewards Points: 170
Question
Tree Saw advice & opinions?
Hi, looking for some advice on manual tree saws. I need to trim some smaller branches, 2"-3" diameter, but the problem is they are over a cliff. In other words, I need to reach OUT rather than UP. This is to improve the view due to trees growing up the side of the cliff.
For homeowner usage do I need to spend a zillion dollars on a Silky saw, or will a less expensive saw work as well for occasional use. How about the ATSS saws, the Marvin saws, or the accu-measure 27' saw? Any others? Thanks for your help
Oh-Fudge is offline   Reply With Quote
Old 04-30-2013, 03:33 PM   #2
Too Short? Cut it Again!
I have not bought a pole saw/tree pole pruner in some time but I cannot imagine that they are that outragesouly expensive. After all, we are talking simple tools on a stick! Get yourself a good one with a decent anvil pruner head and saw combination and a decent aluminum extension handle to reach 8-12' or so. I think you will find you will use it a lot.
Just looked online and saw a nice one with a decent fiberglass handle for $30! Something like this is what you need I think. Electric poles saws seem gimmicky but were $100 or so.
Old 04-30-2013, 03:46 PM   #3
Is this wire Hot?
Oh-Fudge's Avatar
Rewards Points: 170
Silky's, top-of-the-line runs close to $300 (http://www.amazon.com/Silky-179-39-T.../dp/B0014CC4WK) That might as well be a bazillion to me. I am looking for a 21 footer, or so, at around $100-$150. Seeking opinions on which is the best for the $$.
Old 04-30-2013, 03:49 PM   #4
If you were going to use the thing on a regular basis it would be worth that kind of money. Heads that swivel are nice I suppose and I am sure the tooling is and steel is better, etc.
You should be able to find something decent with a pruner that operates nicely and a decent saw for $50-60 I should think. Do you have a real nursery near you?
Obviously you do not want something with a pruner head that is going to bind or fall apart. You almost have to look at one in person I think.
Maneuvering anything on the end of a 21 foot pole is going to be a challenge though. You are in for an upper arm workout for sure!
The Following User Says Thank You to user1007 For This Useful Post:
Oh-Fudge (04-30-2013)
Old 06-27-2013, 11:15 AM   #5
Is this wire Hot?
Oh-Fudge's Avatar
Rewards Points: 170
Follow-up, I ended up getting the Jameson FG (yellow) pole, a 6' base pole with two 6' extension sections. A pole saw head unit and the 16" "Mammoth" tri-cut blade. Total $129.
It might be a little pricey, but boy is this thing solid. I've already cut through a 6" limb at 18 feet out over the cliff. Yes, it is a workout, but until they invent a 6 ounce chainsaw onna stick this will have to do .
Old 06-28-2013, 08:45 AM   #6
Keep it clean for the sake of the equipment and the health of what you cut. Oil or WD40 the blade when storing it. Visit a sharpener the first time it acts dull and this will serve you and future generations well.
Oh-Fudge (06-28-2013)
looking for Serious advice and Help on Insulation bfan781 Building & Construction 6 05-19-2010 12:02 PM
Low retaining wall around a tree kimberland30 Landscaping & Lawn Care 24 05-13-2009 09:52 AM
What to do about tree with multiple trunks -Q- Landscaping & Lawn Care 1 04-28-2009 05:36 AM
Any arborists out there? Can you help me with the care of this tree? [pics] perpetualjon Landscaping & Lawn Care 8 02-27-2009 06:51 PM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 12:51 PM
