-   -   Tree Saw advice & opinions? (http://www.diychatroom.com/f16/tree-saw-advice-opinions-178458/)
Oh-Fudge 04-30-2013 01:24 PM
Hi, looking for some advice on manual tree saws. I need to trim some smaller branches, 2"-3" diameter, but the problem is they are over a cliff. In other words, I need to reach OUT rather than UP. This is to improve the view due to trees growing up the side of the cliff.
For homeowner usage do I need to spend a zillion dollars on a Silky saw, or will a less expensive saw work as well for occasional use. How about the ATSS saws, the Marvin saws, or the accu-measure 27' saw? Any others? Thanks for your help :)
user1007 04-30-2013 03:33 PM
I have not bought a pole saw/tree pole pruner in some time but I cannot imagine that they are that outragesouly expensive. After all, we are talking simple tools on a stick! Get yourself a good one with a decent anvil pruner head and saw combination and a decent aluminum extension handle to reach 8-12' or so. I think you will find you will use it a lot.
Just looked online and saw a nice one with a decent fiberglass handle for $30! Something like this is what you need I think. Electric poles saws seem gimmicky but were $100 or so.
http://1.bp.blogspot.com/-q0jsomRa9L...pole+saw+1.jpg
Oh-Fudge 04-30-2013 03:46 PM
Silky's, top-of-the-line runs close to $300 (http://www.amazon.com/Silky-179-39-T.../dp/B0014CC4WK) That might as well be a bazillion to me. I am looking for a 21 footer, or so, at around $100-$150. Seeking opinions on which is the best for the $$.
user1007 04-30-2013 03:49 PM
If you were going to use the thing on a regular basis it would be worth that kind of money. Heads that swivel are nice I suppose and I am sure the tooling is and steel is better, etc.
You should be able to find something decent with a pruner that operates nicely and a decent saw for $50-60 I should think. Do you have a real nursery near you?
Obviously you do not want something with a pruner head that is going to bind or fall apart. You almost have to look at one in person I think.
Maneuvering anything on the end of a 21 foot pole is going to be a challenge though. You are in for an upper arm workout for sure!
Oh-Fudge 06-27-2013 11:15 AM
Follow-up, I ended up getting the Jameson FG (yellow) pole, a 6' base pole with two 6' extension sections. A pole saw head unit and the 16" "Mammoth" tri-cut blade. Total $129.
It might be a little pricey, but boy is this thing solid. I've already cut through a 6" limb at 18 feet out over the cliff. Yes, it is a workout, but until they invent a 6 ounce chainsaw onna stick this will have to do :yes:.
user1007 06-28-2013 08:45 AM
Keep it clean for the sake of the equipment and the health of what you cut. Oil or WD40 the blade when storing it. Visit a sharpener the first time it acts dull and this will serve you and future generations well.
