Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 09-08-2008, 01:21 PM   #1
Tree Removal Question
Next to our new home there is a pine-type tree about 20' tall and about 6" wide at the biggest part of the trunk. Its in a bad place as the sewage line runs out of the house close by and I don't want the roots eventually looking for water so I plan on taking it down.
My question is how can I be sure the roots are dead after I've gotten the tree down? Is there anything I can use on the trunk to take care of the roots?
jte1130 is offline   Reply With Quote
Old 09-08-2008, 01:41 PM   #2
You can use a stump remover. But, it's a long process.
First you let the stump dry out for 6 months. Then you drill holes and apply the powder. Later, they recommend you pouring kerosene into the stump and burn it.
handy man88 is offline   Reply With Quote
Old 09-08-2008, 03:22 PM   #3
Guess I'll have to go with the stump remover chemical as burning is not an option. Its too close to the house and I'm in a residential area.
Old 09-08-2008, 07:37 PM   #4
The ad says that if you light up the stump with kerosene, it smolders, but is no danger.
You can buy this at Home Depot.
http://www.eburgess.com/detail.asp?pid=8460
Old 09-09-2008, 02:13 AM   #5
Kap
Mowing my life away.
You can use Tordon- main ingredient is 2,4d or Garlon-main ingredient is triclopyr. Any brand with those ingredients will do the same job. You apply it to the stump immediately after cutting. use a paint brush and soak the cambium layer. Be sure to read the labels.
I've also used Roundup on smaller trees after cutting.
Kap is offline   Reply With Quote
Old 09-09-2008, 04:02 AM   #6
paper hanger and painter
chrisn's Avatar
If you cut the tree down, the roots most likely will not be an issue.
Old 09-09-2008, 01:19 PM   #7
Kap
With a healthy root system the tree can and will regenerate growth and continue to live.
Old 09-09-2008, 01:49 PM   #8
gravity always wins
I've never seen an evergreen tree regenerate from roots. Deciduous trees, yes. Evergreens? not that I've ever heard. Cut the trunk down to ground level and forget about it. It's only a 6" stump, take an axe to it. It will rot up and disappear. Even the roots of a deciduous tree will die if you keep the new shoots mowed off.
Old 09-09-2008, 06:18 PM   #9
chrisn's Avatar
Right!
Old 09-09-2008, 06:39 PM   #10
As a Forest Technician/Urban Forester I have to agree that after it's cut as low to the ground as you can get it, forget about it, cover it with some soil and it'll rot away, roots and all. It may even leave a bit of a depression in a few years after it's completely decayed.
Coniferous trees don't resprout from the roots.
leafyme is offline   Reply With Quote
Old 09-10-2008, 01:18 AM   #11
Kap
They do here. But a lot of rules don't seem to apply here. I've seen Norfolks do it, and Ironwoods are the worst, especially for root suckers.
Timmbbbberrr - Has anyone done DIY tree removal? Leah Frances Landscaping & Lawn Care 27 05-20-2008 10:11 AM
sub flooring removal question matchley Flooring 7 10-02-2007 09:19 PM
my tree removal estimate elementx440 Landscaping & Lawn Care 7 03-23-2007 12:48 PM
Magnolia tree + septic tank question/problem Jemo General Discussion 5 01-18-2007 10:08 AM
removal of old tree MWD78 Landscaping & Lawn Care 4 12-17-2006 08:33 PM
