Toro Super Recycle 20055 Throttling Issue? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-11-2010, 05:39 PM   #1
Toro super recycle 20055 throttling issue?
I have a Toro super recycler self pace mower model 20055 that I purchased in 2005. Ran great the first year, but it has not run great since. It tends to do a lot of choking almost as though it runs too rich. The throttle on the model is automatic and if I open throttle up a bit the engine revs up an sounds more normal. Does anyone know what my issue might be here? Is there a way to adjust this automatic throttling? Thanks for any advice you might have.
Brian
Go Hawks!!!
Hawkeyes is offline   Reply With Quote
Old 04-11-2010, 08:02 PM   #2
I don't know if this'll help, but I have the same model mower and I affected the throttle once by running into something. It bent the bracket that holds the throttle cable. I forget the number of rpm's it's supposed to run but you could get a tachometer and verify the speed.
VelvetFoot is offline   Reply With Quote
