Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 10-29-2009, 11:13 PM   #1
Default Toro Recycler problem
Have a Toro with Briggs Stratton engine. Still runs as if it wants to stall after cleaning fuel bowl&screw, new plug and fuel line and new gasket between air filter assembly and carb opening. Can not find any carb adjustment screws. Starts up and can't decide whether to stall or run a bit.
Frustrated in Michigan,
Thanks in advance,
Daniel Cairns
cutmedan is offline   Reply With Quote
Old 10-31-2009, 11:17 AM   #2
Try:
http://www4.briggsandstratton.com/di...sp?docid=67021
for info on your model.
bob22 is offline   Reply With Quote
Old 11-02-2009, 04:36 PM   #3
I had the same problem...fixed under warranty by the shop...after a long saga......was told it was the gasket between carb and engine. Did you see this other thread? Toro Recycler mower w/ Tecumseh 6.5 engine - starts and immediately dies
good luck!
piste is offline   Reply With Quote
More On This Topic
Hi! I'm Adam. We're here at The Bird All American Bar and Grill in beautiful downtown Mount Pleasant, Michigan. On behalf of Expert Village, we are going to mix up some drinks today, pour some shots, and have some fun. In this clip, we're going to show... Read More »
Hi! I'm Adam. We're here at The Bird All American Bar and Grill in beautiful downtown Mount Pleasant, Michigan. On behalf of Expert Village, we are going to mix up some drinks today, pour some shots, and have some fun. In this clip, we're going to mix up... Read More »
Hi! I'm Adam. We're here at the Bird All American Bar and Grill in beautiful downtown Mount Pleasant, Michigan. On behalf of Expert Village, we're going to mix up some drinks today, pour some shots, and have some fun. For this body shot, Rachel is going... Read More »
Hi! I'm Adam. We're here at The Bird All American Bar and Grill in beautiful downtown Mount Pleasant, Michigan. On behalf of Expert Village, we are going to mix up some drinks today, pour some shots, and have some fun. In this clip, we're going to pour a... Read More »
Hi! I'm Adam. We're here at The Bird All American Bar and Grill in beautiful downtown Mount Pleasant, Michigan. On behalf of Expert Village, we are going to mix up some drinks today, pour some shots, and have some fun. This is the Irish Car Bomb. We're... Read More »
flame sensor problem junkcollector HVAC 0 10-26-2009 08:10 PM
Grout peeling out from shower floor tiles. What's the problem? hellstorm Flooring 6 10-21-2009 11:15 PM
75 year chimney leak problem mstanleyg Building & Construction 9 10-06-2009 04:02 PM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 08:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 03:51 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
