Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 10-10-2009, 10:22 PM   #1
Default Toro Recycler mower w/ Tecumseh 6.5 engine - starts and immediately dies
I picked up a Toro 22" Recycler mower from the curb a few days ago. It looked relatively new and visually fine. It's got a 6.5 HP Tecumseh engine, model LEV120–361560B. The spark plug looked pretty new, as if the previous owner had just replaced it. Wouldn't turn over. I drained the old gas, monkeyed around with it a bit, and got it to the point that it will start and then die out 2-3 seconds later. Today I went to get a rebuild kit for the carburetor and rebuilt it. It's no better than it was before the carb rebuild.
Any ideas on what else I should be checking on this mower? My knowledge of small engines is very limited..part of the reason I'm doing this is to learn from the experience (and, of course, to have a running mower!)
Pickngrin is offline   Reply With Quote
Old 10-11-2009, 07:24 PM   #2
A nice little project that can drive you crazy. Following site is pretty thorough and should give you much of the info you need. Post back with your progress.
http://repairfaq.ece.drexel.edu/sam/lmfaq.htm#lmaoil
bob22 is offline   Reply With Quote
Old 10-15-2009, 10:14 AM   #3
Default Been there....
Spent my whole summer, literally, trying to get my Toro 22" Recycler bought Aug 2008 to work. Went through everything you could possibly imagine...would take me 30 minutes to type the whole story. The shop had it more than I did this summer. I think the Toro Personal Pace is the best drive out there....but Toro does make its share of lemons and I got one. Mine is a Briggs and Stratton engine.
As part of the carb rebuild did you replace the intake gasket?? That's what it ended up being for mine..and this was done as an in-warranty repair at a local shop....after several other in-warranty repairs earlier in the summer....They replaced and/or doubled up...not sure which...the gasket between the intake/throttle body and main engine. I've heard tell that those sometimes warp or have issues...especially after heating up. This was done to mine I think sometime in August and it's worked fine since. Whereas before it was finicky as all get out...especially in taller wet grass. Good luck and keep us posted.
piste is offline   Reply With Quote
Old 10-15-2009, 05:50 PM   #4
J Calvin Construction
jcalvin's Avatar
I bought a zero turn from a buddy this year that couldn't get it to run for $200. There was a fuel sut-off solenoid that had lost power due to a burnt wire. Took me about 30minutes to diagnose, fix, and start mowing. After a couple weeks, it would start dying after about 10 minutes, if it sat unused for a couple of days, and when I would fire it up it would die in a matter of seconds. I piddled with it on and off for a couple weeks. I checked everything and couldn't find a thing wrong with it. In an act of desparation, I unscrewed the fuel cap and looked inside with a flashlight. Lo and behold, a dead ladybug was in the bottom of the tank. I fished it out and never had another problem. Check for lady bugs!
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Old 10-16-2009, 02:47 PM   #5
When you rebuilt the carb. did you open up the filter bowel for the gas? those bowels like to fill up with debris and water and will cause those surges...perhaps checking that out may help you.
Viper16 is offline   Reply With Quote
Old 10-16-2009, 08:29 PM   #6
Thanks for each of the replies. Fortunately (or unfortunately, as it would have been an easy fix), there were no ladybugs in the tank!
Today, I change the gasket between the intake valve and the engine block. No change in engine behavior -- it still starts and dies almost instantly.
Funny thing, a few days after finding the Toro Recycler with the Tecumseh 6.5 HP, I found another Toro Recycler at the curb in my neighborhood, this one with a Briggs & Stratton 6.5. I figured between the two mowers, hopefully I'd get at least 1 running well, but maybe both. Well, the Briggs engine started up but gave off heavy white smoke. Turns out the previous owner had too much oil in there. Today I removed the carb bowl and cleaned it. Replaced the air filter. Starts up beautifully now, with barely a tug on the cord! So this one is running nicely, but I haven't figured out the problem with the Tecumseh engine yet.
Viper asked if I opened up the filter bowel for the gas? Do you mean the bowl under the carb? Otherwise, I am not famiilar with a filter bowel, and didn't find anything when I just Googled the term.
Thanks again
Old 10-17-2009, 11:00 AM   #7
Yes, that bowl. Try to remove the bowl, float, and needle valve. Spray Gumout carb cleaner up into the hole the needle valve sits in to get rid of any debris/build up that may be gumming up the works. Reinstall and try again. Have to assume you are getting spark (does it get wet after a few pulls of the starter? Right plug?). Choke/linkage adjusted correctly? Mixture and idle screws at right settings?
Old 10-17-2009, 12:14 PM   #8
Oh, OK. When I did the rebuild, I disassembled the bowl, etc., sprayed Gumout, installed a new needle, etc. I am getting spark (I used an inline spark tester to check). I don't see any mixture or idle screws on this carb. I believe the choke/linkage is adjusted correctly, but last night I was looking online for a picture of how it should look.
Old 10-29-2009, 11:56 AM   #9
Ok, I got the Toro with the B&S engine running like a champ with a minimum amount of effort, and I was getting frustrated with the Tecumseh, so I listed it on Craigslist and sold it the same day. I'm happy with the outcome.
Thanks for all of the input and suggestions.
Old 10-29-2009, 10:20 PM   #10
Nothing like selling off a problem; best fix of all!
Old 10-29-2009, 10:28 PM   #11
:-) Well put!
More On This Topic
Caring for a lawn mower is the best way to ensure a safe and trouble free season of lawn care. Maintaining a well-lubricated engine and keeping the blades in top shape reduces problems associated with bad timing and dull grass cutting. Use the following... Read More »
Ok, here we are back, I'm going to talk about starters. Different types of starters. Briggs and Stratton came out with what I think is probably the best starter and of course they don't use it anymore. But you'll see that there's a big hole in here and... Read More »
Final Check of a Lawn Mower
Final Check of a Lawn Mower by Expert Village
Hi, my name is Peter Gutwein and today we’ve been looking at doing some minor repairs to a mower. We started off with sharpening the blade and doing an oil change and an air filter, spark plugs and we got into some more complex things like... Read More »
Hi, I'm Mark Sullivan for Expert Village and today we're going to teach you how to change the oil in a standard internal combustion automobile engine. And now you want to disburse of this oil properly. You can see if you look into the oil pan, how dirty... Read More »
Caring for a lawn tractor is somewhat similar in practice as caring for a walk behind mower with some minor differences. Keeping a lawn tractor in top shape keeps repair bills down and adds to its years of trouble free service. Follow these steps to care... Read More »
Engine Slowly Loses Power and Dies While Driving slickshift Automotive Repairs 16 01-15-2007 01:34 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
