TORO Lawn Mower - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-31-2011, 02:41 PM   #1
Rewards Points: 79
TORO Lawn Mower
I have a four year old, TORO Variable Speed, Walk behind, Steel deck lawn mower and today the transmission area started to doing a knock, knock sound and she was not pulling. I rotated her up on the rear wheels and engaged front drive and the wheels spin fine, but when I put the front wheels on the ground and engage the drive she just does not want to pull. I suspect the belt, however this mower has had the transmission and belt assemb;y replaced (under warranty ) 18 months ago so I am suspiciopus of her. I can do a belt check, anything else I should look for?
vabear is offline   Reply With Quote
Old 09-01-2011, 03:02 PM   #2
Rewards Points: 79
TORO POS Lawn Mower
I lied, mower is only 3 years old and the replaced transmission one year old. Removed cover from transmission belt drive and the pulley is wobbling like crazy, so I guess that is one issue, With rear wheels off ground and front dricve engaged, left wheel rotates, stops and then starts rotating agin, ri9ght wheel is fine. Also the pulley above the transmission when fully engaged, hits the end of the fiberglass cover (factory technician adjusted after last transmission change). Just can't win this lawn mower war.
Toro Lawn mower repair spyrod59 Landscaping & Lawn Care 5 08-20-2014 08:46 PM
Toro 20332 Recycler lawn mower pcarlson Landscaping & Lawn Care 6 08-10-2011 06:20 PM
I've replaced the battery and the solenoid in a 19Hp Toro lawn mower. Mr Chips Landscaping & Lawn Care 4 07-14-2011 09:28 AM
Solaris Lawn Mower review dive_instructor Landscaping & Lawn Care 0 06-03-2011 10:29 AM
Solar Charged Brushless Lawn Mower Educator Electrical 2 04-20-2008 01:43 PM
