Toro 824 Wont Start - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 11-28-2010, 02:12 PM   #1
Toro 824 wont start
hey....
i need help with my toro 824...it hasnt been running for a long time like a couple of years...i tried to start it up n it didnt work...i tried to look at what was wrong and i found that the gas line was full of crap...so i cleaned it...the gas is running....
i dont now much about snowblowers...
it would be cool to get help before the snow comes....
give me some options of what to look at n stuff...
thank you
francois is offline   Reply With Quote
Old 11-28-2010, 04:52 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,354
Ayuh,... There's probably More of the Crap in the carb that'll need to be cleaned out....
And, check the sparkplug to see if it's firing...
Old 11-28-2010, 05:11 PM   #3
Rewards Points: 476
Originally Posted by francois View Post
hey....
thank you
Remove carb. and clean it very good . Take the float off and the needle and clean the seat where the needle goes . Also i belive a good soaking and take a air hose and blow it dry install needle back in the seat and float back. make sure that the bowel if it has a gasket or rubber gasket that it get put back right. Be sure and maybe drain the gas tank and put fresh gas in the tank . If it is a 2 cycle mix the oit and gas. Get some gas treatment that will keep the gas from gelling again. I know about engine's but i live in florida so don't own a snow blower's ?? this should get the engine running
del schisler is offline   Reply With Quote
Toro Self Pace mower, ran over pipe HELP? schuetzen Landscaping & Lawn Care 4 08-17-2009 11:15 PM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Landscaping & Lawn Care 3 08-13-2009 10:58 AM
my toro 824 snowblower wont run..ys that?? chaz824 Automotive Repairs 1 12-21-2008 06:51 PM
Brand new PAYNE PG9MAB won't start . Error code 12 tp618 HVAC 3 12-19-2008 09:21 PM
Blue smoke at start up, and shudder at idle fauer Automotive Repairs 6 08-22-2008 11:39 AM
