Topsoil Height When Seeding - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-17-2013, 12:24 PM   #1
Rewards Points: 422
Topsoil height when seeding
Before seeding, should the topsoil height be the same as the surrounding grade to allow for settling, or should it be the same height? If higher, how much higher? We are seeding where our pool used to be, and I'm trying to figure out if I need more topsoil. Thanks.
Jim McC is offline   Reply With Quote
Old 10-17-2013, 12:50 PM   #2
Rewards Points: 120
Don't know, but assuming that you maybe have 6" or so of loosened soil on top after digging out the sand and adding soil, I would probably keep it up about 1/2", maybe more in the center if it was deeper there. What I usually do though, if I'm concerned enough, is spread the soil to about where I think it should be, then plant my feet firmly in a few areas, see how it feels compared to the surrounding soil, check the height, fluff my footprints back up, then add more soil if it needs it, or just seed.
Old 10-17-2013, 02:18 PM   #3
Rewards Points: 42
After spreading the topsoil, roll it out with a roller (one of those plastic jobs that you fill with water). You'll likely have to add more soil (roll again) to get the grade to match. Then seed and re-roll. If you don't compact the topsoil, it's going to be bumpy after it settles on its own.
Dan
djlandkpl is offline   Reply With Quote
Old 10-17-2013, 04:14 PM   #4
Rewards Points: 422
Thanks. I'm getting conflicting opinions on whether to seed now or wait til spring, from local landscape supply houses. A couple said the seed may freeze and need to be redone in the spring, and a couple said it will be dormant and come up in the spring just fine. I'd rather get more topsoil and do it now. I already bought the seed and straw. I was also told if I wait til spring I may have to rototill again, and I DO NOT want to do that. What do you guys think? I live about 25 miles west of Milwaukee, WI. Thanks.
Old 10-17-2013, 06:08 PM   #5
Rewards Points: 42
Ideally, you would have seeded in late August/early September. I don't like seeding in the spring due to the weed seed that can quickly take over. It's probably too cool now for the seed to germinate, but that will depend upon the type of grass you plant. I have seeded late in the fall with the intent that the seed freeze and germinate in the spring. I think it was successful.
I doubt you will need to rototill if you wait. You will need to loosen the surface so the seed has some place to go. If you can afford to waste seed, sow it now. If you can't then wait for spring.
Dan
Old 10-17-2013, 07:35 PM   #6
Rewards Points: 422
Thanks. I was told today that if I seed now, I do not need to water it because it will be dormant. Is that correct?
Old 10-17-2013, 09:35 PM   #7
Rewards Points: 42
Correct. You don't want it to germinate.
Dan
Gas Fireplace Flame Height Control chh HVAC 3 09-09-2012 11:22 AM
What should be the height of wall? so roof pitch is 10 feet... vikasintl Roofing/Siding 2 07-04-2012 10:32 PM
ridge height calculation oxbow Building & Construction 19 01-14-2012 07:26 AM
Code for basement ceiling height RDS Building & Construction 3 04-22-2008 10:46 AM
Height of Fence = Height of Posts Necessary Dallas Building & Construction 2 11-05-2007 09:47 AM
