Timber Retaining Wall - Screws Vs Spikes - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-11-2012, 01:30 PM   #1
gruntman's Avatar
Rewards Points: 79
Timber retaining wall - screws vs spikes
Im expanding my existing playground by building a timber retaining wall that will be about 5 (6x6) timbers tall (dimensions = 12 x 10). The yard is sloped so you will only be able to see 3 on the back and about half a timber in the front. I'm securing the bottom row with rebar. Regarding the remaining timbers - what is the best way to secure them to one another - spikes vs timber loc screws?
gruntman is offline   Reply With Quote
Old 06-11-2012, 06:43 PM   #2
Rewards Points: 83
I would pre drill and use spikes. Even with pre drilling, installing an 8 to 10 inch screw is going to put a serious strain on whatever your are using to install it with. Times that by how ever many dozen you install and I could see frying most light to medium duty screw guns.
rubberhead is offline   Reply With Quote
The Following User Says Thank You to rubberhead For This Useful Post:
gruntman (06-11-2012)
Old 06-11-2012, 09:59 PM   #3
gruntman's Avatar
Rewards Points: 79
I didnt think of that. I just bought a Bosch 1013VSR drill and I dont want to burn it up right from the start. I started demoing a section of the old structure and those spikes actually hold very well. Thanks
Old 06-12-2012, 12:37 AM   #4
Rewards Points: 83
Yeah I actually built a retaining wall a year (two?) ago out of 6X6 and used galvanized ardox nails. Even after pre drilling I would up using a small sledge hammer to install the spikes. Amazing how well it sucked everything together.
Old 06-14-2012, 03:59 PM   #5
gruntman's Avatar
Rewards Points: 79
I tried using 4ft rebar to stabilize my initial row but I hit rocks and I can't get past a foot. Is there anything else I can do?
Sent from my iPhone using DIY Forum
Old 06-16-2012, 02:02 AM   #6
Use/rent hammer drill to get past rocks. I don't use nails to build a timber wall, I use steel bar 3/8 steel bar.
Also when butting a timber to timber I use Heat bend the bar like a large staple
Drill about 7 inches from each butt end. From those holes run the chainsaw from hole to hole making a slice in top of both timbers now drive steel staple through holes and that pins bottoms to top and the staple end ( counter sunk) locks the two timber at the same level for shear pressure.
I don't see any Tie backs mention here why?
21boat is offline   Reply With Quote
Old 06-16-2012, 07:54 AM   #7
gruntman's Avatar
Rewards Points: 79
Tie backs same as dead men? I have them coming from both sides.
Old 06-16-2012, 10:42 AM   #8
MarginallyQualified
Rewards Points: 2,464
use a bigger hammer, or get a bigger guy on the hammer or move the hole
Old 06-16-2012, 01:10 PM   #9
gruntman's Avatar
Rewards Points: 79
I think I'm on ledge. What if I piled boulders, 45 -50 lbs ones, at the base of the bottom course. That might hold them in place?
Old 06-24-2012, 06:46 PM   #10
gruntman's Avatar
Rewards Points: 79
I put crushed stone against the inside of the wall wrapped in landscape fabric and the topped with more stone. What do I put on top? Dirt? I'm going to top it all off with playground chips when I'm done.
Footing for 12 inch retaining wall tibetie Building & Construction 15 09-19-2011 02:45 PM
securring an existing railroad tie retaining wall secondguesser Landscaping & Lawn Care 1 07-02-2009 08:52 PM
Timber retaining wall repair *Kennedy* Landscaping & Lawn Care 2 03-26-2009 06:02 PM
Replacing large retaining wall notfromaroundhere Landscaping & Lawn Care 6 12-17-2008 12:30 AM
Drainage ? for an 8' tall Retaining Wall White Elk General DIY Discussions 19 12-04-2008 08:11 PM
