06-10-2010, 06:25 PM
#1
Till and reseed entire lawn or repairable?
06-10-2010, 06:26 PM
#2
06-10-2010, 06:46 PM
#3
The weed looks like Plantain and also a bunch of clover. You could try a weed and feed now with 2-4d and over seed in the fall.
Chris
06-10-2010, 07:00 PM
#4
Just re-seed over existing lawn or re-till and respread?
06-10-2010, 07:15 PM
#5
Don't know it all, yet!
And I think I saw some wild violets in there.
Any broadleaf only weed killer will get rid of most of this. You will probably have to hit it a couple of times. Treat after a good rain- "when weeds are actively growing" according to most labels.
This fall I would aerate and overseed and fertilize with a high P formula.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
06-10-2010, 07:17 PM
#6
Just reseed over existing lawn- depending on where you live, you'll probably want to wait until early Fall. Seeding this time of year- going into summer- makes it difficult to get a lawn established, unless you can water twice per day for the first 3-4 few weeks after germination. If it gets real hot and you miss a day watering, the new grass could die and you would have to start over.
Chris
06-10-2010, 07:28 PM
#7
Sorry. From northern NJ. Right next to NYC.
06-10-2010, 07:31 PM
#8
2nd or 3rd week in September would be ideal for over seeding in your location
Chris
06-10-2010, 07:33 PM
#9
Do I have to get new soil as well? Or just break up existing soil?
06-10-2010, 07:39 PM
#10
No additional soil necessary unless you have low spots. Use an iron rake to scarify the area to be seeded so that the seed can be covered with 1/4" or so of soil. If you disturb the existing grass, that's ok.
Chris
06-10-2010, 07:44 PM
#11
Do you pros recommend any specific weed killer at Lowes or Home Depot?
I also purchased the Toro e-Cycler and plan on mulching. Good idea?
What kind of grass seeds do you recommend?
06-10-2010, 07:45 PM
#12
Yup!!
I like a mix of Fescue, Perennial Rye, and a little Bluegrass
Chris
06-10-2010, 08:31 PM
#13
http://www.amazon.com/Bayer-502874B-.../dp/B000RUEBIK
So if I spray this on my weeds, clovers, and violets, it won't kill my grass as well?
It says it won't so I should be fine.
After I spray the my weeds and they die, do I have to dig out the weeds? Will they just decompose if I leave it there?
Also, is this spray safe for my dog?
06-11-2010, 07:18 PM
#14
You should be fine with this. If you have concerns, spray a test area first. Note the temperature restriction- you may need to do this in the very early morning.
After the weeds are dead, you don't have to do anything else. They will go away after a couple of cuttings.
As for the dog, with any chemical application, ALWAYS keep animals and children out of the area until the product dries. Look for a re-entry interval (REI) on the label. This will tell you how long to keep anyone out.
06-15-2010, 03:06 PM
#15
Do you think it will be better to kill the weeds and then re-till the entire lawn and just seed? Or is that overkill?
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
