Threading Cable Under Concrete Walkway - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 02-27-2012, 03:37 PM   #1
Rewards Points: 1,062
threading cable under concrete walkway
I have a need to thread some ground wire under an existing concrete walkway about 3' length. Was wondering if there is a good way to do it without undermining the walkway.
Old 02-27-2012, 04:28 PM   #2
DIY staff
Rewards Points: 7,174
Water blast it---
Dig a hole along side the slab--and another where you want the wire to come out--
Rig up a length of 1/2" or 3/4" PVC pipe to your garden hose---and start pushing that pipe under the slab while the water is blasting---
Fast--efficient and cheap---Pipe could be left under the slab as a conduit,if you wish.--Mike---
Thurman (02-27-2012)
Old 02-27-2012, 09:49 PM   #3
Great, thanks
Old 02-27-2012, 09:58 PM   #4
But I worry that might loosen the dirt under the slab and cause concrete cracking in the future
Old 02-27-2012, 11:10 PM   #5
Rewards Points: 626
Get a cement saw and cut what you need out lay down some PVC pipe for a conduit and your put your wire in the pipe back fill with new cement. that would be the best way.
Nailbags is offline   Reply With Quote
Old 02-27-2012, 11:14 PM   #6
Rewards Points: 280
Dig hole big enough to work in. Flatten end of steel pipe. Drive pipe under walk while turning with pipe wrench, this stops pipe from wandering. Cut off end of pipe and insert plastic bushings, run wire. I've done 10 feet this way.
jjrbus is offline   Reply With Quote
The Following User Says Thank You to jjrbus For This Useful Post:
amakarevic (02-27-2012)
Old 02-27-2012, 11:15 PM   #7
most certainly not. my concrete is so beautiful and perfect (done it myself), i don't wanna have a patch. i think i'd rather donate a kidney or something.
but thanks for the idea.
Old 02-27-2012, 11:22 PM   #8
Rewards Points: 626
OK do it the hard way.
"Dig hole big enough to work in. Flatten end of steel pipe. Drive pipe under walk while turning with pipe wrench, this stops pipe from wandering. Cut off end of pipe and insert plastic bushings, run wire. I've done 10 feet this way."
The Following User Says Thank You to Nailbags For This Useful Post:
Old 02-28-2012, 12:04 AM   #9
Rewards Points: 280
Drive pipe with sledgehammer!
amakarevic (02-28-2012)
Old 02-28-2012, 12:07 PM   #10
Rewards Points: 338
I haven't had any success this way. It seems like I always have something in the way at my starting end and wind up heading deeper. I know other people that it's worked for though.
petey_c is offline   Reply With Quote
Old 02-28-2012, 01:44 PM   #11
Drive rod or pipe with sledgehammer or use a garden auger
at a 30 degree angle from the horiz. for 1.7', then pull out rod or pipe with a comealong.
Do same on other side.
Both holes meet in the middle. No undermining going on because the dirt spreads the downward force from the sidewalk around the hole.
Mark the length first on the rod/pipe/auger.
Old 02-28-2012, 03:08 PM   #12
Rewards Points: 76
It's going to vary, depending on soil conditions. For hard packed soils, water blasting works well, and if you do that, it's really handy to put a valve between the hose and the pipe, so that you have control of the flow right where you want it. For lighter soils, where the water may displace more soil than desired, I have used a piece of conduit a bit longer than what I actually needed, cut four V's in the leadng edge, to give it some teeth, leaving enough on the trailing end to get a pipe wrench on it, then, once it's through, cut off the ends and install the bushings. A good bite with the pipe wrench will allow you to turn and push simultaneously. I can't recall having had to do this in heavy clay, but suspect that you might need a bit more "umph", in which case you can probably rent a hand auger from your local rental shop.
garden shed on existing concrete pad hartkem Building & Construction 6 10-27-2011 08:46 PM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 11:58 AM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 08:47 PM
Walkway near big trees--how to deal with roots! jetstover Landscaping & Lawn Care 16 07-26-2011 06:21 PM
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 09:37 PM
