Temporary Fix For Muddy Driveway? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-19-2014, 08:07 PM   #1
Rewards Points: 33
Temporary Fix for Muddy Driveway?
All of the snow is melting up here in Michigan and my gravel driveway has become a mud pit. The more I drive on it the worse it is getting, so I'm wondering if anyone would be able to suggest a cheap temporary fix until the ground finishes draining.
Once spring hits I will be able to put in a more permanent solution.
Thanks!
bigbopper180 is offline   Reply With Quote
Old 03-20-2014, 09:40 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 590
Ayuh,.... Wear galoshes,...
Bondo is online now   Reply With Quote
Old 03-20-2014, 10:16 AM   #3
firehawkmph's Avatar
Rewards Points: 1,822
I just dumped and spread about ten tons of 57 limestone on mine yesterday.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 03-20-2014, 11:26 AM   #4
Quick-Home-Buyers
QuickHomeBuyers's Avatar
Add more gravel. If it's deep enough add bigger size gravel first then add the smaller size on top. This should give you some room for the water to drain.
QuickHomeBuyers is offline   Reply With Quote
Old 03-20-2014, 02:54 PM   #5
Just finished spreading everything. This is actually a second drive that goes to my shop.
No more mud.
Mike Hawkins
How to repair a cracked driveway or walkway rfrick7@yahoo.c How To Guides 8 06-15-2015 04:59 AM
Driveway + Walkway buildup question r0yal Landscaping & Lawn Care 2 03-24-2012 09:42 AM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 09:14 PM
Need to have driveway paved and graded Mikey Palmice Landscaping & Lawn Care 3 05-20-2009 08:07 PM
