Techumseh Engine Repair - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-14-2009, 09:48 AM   #1
techumseh engine repair
Hi
I have an older Tecumseh H60 (6HP horizontal) engine. I had to pull the head gasket to change it, and several of the head bolts were rusted severely, so they got mangled upon removal.
Now you know since the head is flat, I just assumed when I took them out (and I was cursing the rusted ones anyway) that they were all the same, so I didn't pay any attention to what bolt went where.
I went to the outdoordistributors dot com web site and used their online parts diagram. It lists the following head bolts, (item 36 on their list) but does not list quantities or locations:
650697 5/16-18, 2 1/2
650695 same, 2 1/4, Grade 8
650694 same 2"
So, interestingly, the 1st and the 3rd numbers are about a buck each at outdoordistributors or jackssmallengines, but the middle one is two bucks. It was the only one listed as a Grade 8.
My questions to any Tecumseh expert:
1. Do they use all the same bolts, or do I need to measure the depth of each tapped hole in the cyl block?
2. If they are mixed, why?
3. Should I use the Grade 8 for all of them?
4. Why the price difference if they're all grade 8?,etc.
This engine if probably from the late 60s, an Ariens snowblower. I have no idea if it's original or they ever worked on it. It was running when I got it, but I had to take it apart for various reasons.
Thanks for any help,
John
johhnyx is offline   Reply With Quote
Old 07-14-2009, 03:05 PM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
It's not uncommon for small engines to use different length head bolts depending on what they need to thread into or how far they need to reach for good solid metal. I'd measure the depths if you can't measure the original bolts. My guess on the price is that 2-1/4 is more of an odd size. Odd sized fasteners are usually higher priced because of lower demand.
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
Small engine repair tripower Tools 2 07-09-2009 03:28 AM
Small Engine Repair Two Lamentations General DIY Discussions 3 01-30-2009 02:10 PM
small engine repair oletrkguy General DIY Discussions 24 12-08-2008 05:04 AM
Small engine problem rkhpapa General DIY Discussions 1 12-09-2006 08:00 PM
